Window Sash Removal Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-07-2012, 07:49 PM   #1
Window sash removal question
What would be the proper way to remove both the upper and lower sashes for stripping and repainting? The sashes sit in a metal channel, and I do not want to ruin the channel. There are not long coil type springs to tension the windows, but rather metal bands/straps that coil up in a holder at the top of the window header. The stop is removed, and new stop and jamb extensions will be added after windows are re-installed. Tried to show the sashes and the channel in the pictures. Thanks, David.
Window sash removal question-window-sash-upper-room-004.jpg   Window sash removal question-window-sash-upper-room-003.jpg   Window sash removal question-window-sash-upper-room-002.jpg   Window sash removal question-window-sash-upper-room-001.jpg
edselsouth1 is offline   Reply With Quote
Old 04-07-2012, 07:59 PM   #2
Rewards Points: 14,026
Those are really old style windows that the tracks have been stapled in place.
I know of no way they can come out without distroying the tracks.
You would be way ahead of the game to remove the whole thing and install new replacement windows.
There would be no more air leaks around the back side of those strips, and they would be far more energy efficient. Plus no more sticking windows and no more painting.
Old 04-07-2012, 08:40 PM   #3
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
In the first pic where the wall meets the window frame. The gap between them.
Slip a reciprocating saw in there with a metal cutting blade.
Once molding is removed you usually have that gap all the way around the window.
sublime2 is offline   Reply With Quote
Old 04-07-2012, 09:27 PM   #4
Window sash question
joecaption, sublime2.... Thanks for your replies. Yes, those are old style windows, to match the old house (1861). Historic district, etc. I 'll try to cut around the window to remove it, then I can disassemble it for paint and repairs. One down, sixteen to go!!! Thanks, David.
Retrofit window flashing question dragondoom295 Building & Construction 1 09-06-2011 08:08 PM
Replacement window question on install... tidal9 Carpentry 1 08-16-2011 10:18 PM
Question for Jeep GC Window Regulator dukes32 Automotive Repairs 0 08-10-2011 10:25 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
Sash Window renovation DED Carpentry 1 05-25-2005 01:32 PM
