Window Replacements - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 02:17 PM   #1
Window replacements
my bedroom windows are rather small. I want to keep the width measurements, but I sure would like to make them taller, bringing them closer to the floor. How would I go about doing that? Would doing this greatly increase my cost in replacing my windows?
wheelin2serve is offline   Reply With Quote
Old 03-03-2013, 02:25 PM   #2
Rewards Points: 13,450
Got some pictures.
What type siding do you have?
A whole lot harder and more expencive, got to open up the inside and outside walls, reframe the whole opening.
Old 03-04-2013, 06:11 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
As far as increasing the size of an existing window opening, that is probably the easiest and most inexpensive way. That said, any type of expansion is going to add a bunch of $$$ to the project over a simple replacement. If you are just modifying one or two, it might not be that bad in the scope of the entire house full of windows.... As joe said, some pics of the interior and exterior would help as well.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-04-2013, 11:34 AM   #4
chb70's Avatar
Increasing the length of the window will definately add costs to the project. Adding the length to bottom is the most economical because you don't need to tear open a larger area to replace the header and jack studs. Depending on the type of exterior you have will be the biggest cost factor.
RSC Builders, Inc
Can You Dig It!
Complete Roof
chb70 is offline   Reply With Quote
New replacement window problems iminaquagmire Windows and Doors 7 11-11-2011 11:56 PM
Window replacements Simonton or Simington?? terry arias Building & Construction 1 10-25-2010 02:16 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
