Window Replacement Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 01:20 PM   #1
Landlord
Rewards Points: 89
Window replacement question
I have old aluminum builders windows. House was built in 1992. Is it possible to use replacement windows you get from lowes on these? or do I need to go new construction. If so...how do you do it?
Window replacement question-window1.jpg   Window replacement question-window2.jpg
cocean is offline   Reply With Quote
Old 12-06-2012, 01:27 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
It looks like that brickmold (exterior trim) is part of the window, so it may all need to come out. If that is the case, you may as well go with a nailing fin (new construction) install. What is the jamb depth on those? If less than 3 1/4", you'll need to rip down those jamb extensions as well.
There may be some other options, but it is difficult to tell by a couple pictures.
On product, if you are looking at Lowes, the Plygem Premium is the only thing that I'd recommend as decent.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 12-06-2012, 01:28 PM   #3
Rewards Points: 13,270
Replacement windows will not work. Going to have to go with new constrution.
At the same time replace all that old brick molding with vinyl bick molding.
Old 12-06-2012, 01:37 PM   #4
Landlord
Rewards Points: 89
no, brick molding comes off,,,this is where i'm at
Old 12-06-2012, 01:38 PM   #5
Landlord
Rewards Points: 89
yeah, that is what I am doing, and then all the siding is bad too, so getting hardi plank, just wanted to go a simpler route for the other 15 bad windows
Old 12-06-2012, 01:40 PM   #6
Landlord
Rewards Points: 89
is there any way to easily detach from inside. I did one years ago and it was a nightmare to get it out(basically interior side) what steps should I take this time
Old 12-06-2012, 02:17 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I see... No easy way. Cut the siding back (or remove it), and then remove the window. The flange makes it impossible to remove from inside.... A replacement window could be used , but it would need some high-level metal work to be flashed properly. Your best course of action is a new construction window.
www.HomeSealed.com
Old 12-06-2012, 02:19 PM   #8
Landlord
Rewards Points: 89
are the fins the only thing holding the window in place? mine are stapled
Old 12-06-2012, 02:29 PM   #9
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Generally speaking, yes. Unless you see screws through the jambs.... Remove the glass and then get a pry bar behind the fins. You have already done the hard part in getting the nailing fins exposed for removal.
www.HomeSealed.com
Old 12-06-2012, 05:07 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
No easy way to do this one correctly here.
Old 12-06-2012, 05:25 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
I'm installing new construction windows in my addition....they have the nailing fin that goes all the way around....if you want, I can post up some pics....
For the most part, new construction windows look like they would be your best bet....but a little late in the year to be doing it....
Replacement window in new remodelled opening otherman Windows and Doors 3 09-24-2012 02:33 PM
basement replacement window 32"x24" slider LMHmedchem Windows and Doors 12 08-29-2012 12:23 PM
window replacement question qchawkfan General DIY Discussions 3 10-17-2010 04:21 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Basement window replacement topher0524 Building & Construction 7 05-21-2009 03:59 PM
