-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window replacement question (http://www.diychatroom.com/f104/window-replacement-question-165744/)
cocean 12-06-2012 12:20 PM
2 Attachment(s)
I have old aluminum builders windows. House was built in 1992. Is it possible to use replacement windows you get from lowes on these? or do I need to go new construction. If so...how do you do it?
HomeSealed 12-06-2012 12:27 PM
It looks like that brickmold (exterior trim) is part of the window, so it may all need to come out. If that is the case, you may as well go with a nailing fin (new construction) install. What is the jamb depth on those? If less than 3 1/4", you'll need to rip down those jamb extensions as well.
There may be some other options, but it is difficult to tell by a couple pictures.
On product, if you are looking at Lowes, the Plygem Premium is the only thing that I'd recommend as decent.
joecaption 12-06-2012 12:28 PM
Replacement windows will not work. Going to have to go with new constrution.
At the same time replace all that old brick molding with vinyl bick molding.
cocean 12-06-2012 12:37 PM
1 Attachment(s)
no, brick molding comes off,,,this is where i'm at
cocean 12-06-2012 12:38 PM
yeah, that is what I am doing, and then all the siding is bad too, so getting hardi plank, just wanted to go a simpler route for the other 15 bad windows
cocean 12-06-2012 12:40 PM
is there any way to easily detach from inside. I did one years ago and it was a nightmare to get it out(basically interior side) what steps should I take this time
HomeSealed 12-06-2012 01:17 PM
I see... No easy way. Cut the siding back (or remove it), and then remove the window. The flange makes it impossible to remove from inside.... A replacement window could be used , but it would need some high-level metal work to be flashed properly. Your best course of action is a new construction window.
cocean 12-06-2012 01:19 PM
are the fins the only thing holding the window in place? mine are stapled
HomeSealed 12-06-2012 01:29 PM
Generally speaking, yes. Unless you see screws through the jambs.... Remove the glass and then get a pry bar behind the fins. You have already done the hard part in getting the nailing fins exposed for removal.
Windows on Wash 12-06-2012 04:07 PM
+1
No easy way to do this one correctly here.
ddawg16 12-06-2012 04:25 PM
I'm installing new construction windows in my addition....they have the nailing fin that goes all the way around....if you want, I can post up some pics....
For the most part, new construction windows look like they would be your best bet....but a little late in the year to be doing it....
