Window Replacement - Pella - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-29-2011, 04:15 PM   #1
window replacement - Pella
I have a Pella window with fixed transom above it. It is double pane (apx 10-12 years old). One of the layers of glass is broken. I can not determine how to remove the transom to replace the glass. There are no screws or clamps visible. Any suggestions?
G Donald is offline   Reply With Quote
Old 09-29-2011, 05:44 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You won't want to remove the entire transom just to replace the glass, which likely is impossible anyway. There will be removable glazing beads on one side, and probably a bead of silicone on the other to remove the glass from the frame. You can then get a new piece made up at a glass shop (although, it would be better to get a new piece prior to pulling out the old one).... and I realize that this is a diy forum, but a lot of times the glass shops will do the install for you pretty cheap.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
oh'mike (09-29-2011)
Old 09-29-2011, 06:00 PM   #3
Rewards Points: 558
Contact pella and see if your window is still under warranty.
epson is offline   Reply With Quote
Old 10-03-2011, 04:32 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I don't believe that Pella has ever warrantied glass breakage.
www.HomeSealed.com
Old 10-03-2011, 06:21 PM   #5
Rewards Points: 558
If it was accidental then no, if it was a manufacture defect that showed up later then yes.
Old 10-03-2011, 11:01 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
After 10-12 yrs, Im guessing that it is not a manufacturers defect.
www.HomeSealed.com
Old 10-04-2011, 09:57 PM   #7
Rewards Points: 558
http://pella.com/owners-manuals-and-...r_Warranty.pdf
Old 10-05-2011, 06:58 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Thanks for proving my point epson :
"Nonlaminated Glass. Transferable Twenty-Year (20-Year) Limited Warranty.
Pella warrants that nonlaminated glass in Covered Pella Products shall be free from premature failure or permanent
material obstruction of vision due to a failure of the glass seal for twenty (20) years from the date of sale by Pella or its
authorized dealer. If Pella is given notice of a glass defect occurring within twenty (20) years of the date of sale by Pella or
its authorized dealer, Pella shall, at its sole option: 1) repair or replace the defective glass (with cost of labor included only
within two [2] years of the date of sale by Pella or its authorized dealer) or 2) refund the original purchase price."
The op doesn't have seal failure or obstruction. He has a broken pane of glass.... Further down in the warranty it also specifies that breakage is not covered.
.... There is no language that I see that refers to stress cracks, but I highly doubt that it would be covered given the verbiage... In addition to the fact that a stress crack (or any other manufacturer defect that would result in breakage) would have shown up far before 12 years in service.
www.HomeSealed.com
Old 10-06-2011, 07:46 AM   #9
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,292
Contact Pella to see if they can sell you a re-make or contact a local glazing company for a price from them on a remake.
Pretty easy fix.
Old 10-06-2011, 09:39 PM   #10
Rewards Points: 558
no problem anytime...
Old 10-19-2011, 08:00 PM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Originally Posted by jennifer20 View Post
You can replace the broken glass of the window. You can get glass from the glass show room and replace it.
The "glass showroom", huh???
www.HomeSealed.com
Install replacement window while keeping new construction window in place key1cc Windows and Doors 9 03-25-2011 08:15 AM
Basement window replacement Atskodinski Building & Construction 9 03-21-2011 03:26 PM
Replacement Window Installation Cost asr1715 Remodeling 1 02-08-2010 10:26 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Vinyl Window Replacement aschau01 General DIY Discussions 2 12-23-2008 05:17 PM
