Window Replacement Mull Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 08:26 AM   #1
Rewards Points: 190
Hello! I had 3 windows replaced by a company last summer... Two were single windows in different rooms. Then there was a big window in the living room (middle picture window with a another window, crank window next to it each side) This window I had them replace with two large double hung windows. It came factory mulled.
Since then I have replaced the two windows in my walk in closet with double hung vinyl windows. Very easy! So I am thinking of completing the bedroom windows this week. What my question is they are side by side windows. There is a wooden mull next to them. Would I take that mull out or keep it in? The type of windows I have are from the 1960s. They are 6 pane glass and on the sides you have to push on this spring aluminum bar to pop them out...
ryanb4614 is offline   Reply With Quote
Old 04-21-2013, 08:33 AM   #2
Rewards Points: 2,238
Picture/s would help - inside and outside.
rossfingal
rossfingal is offline   Reply With Quote
Old 04-22-2013, 11:43 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1 on the pics... Generally speaking however, you can go either way. Leave the existing mull or remove it.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-28-2013, 07:13 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,908
If you cut out the existing mull, plan on doing over the interior casing as that is normally required after this option is used.
I, personally, like the wood mull but it is overwhelmingly not structural so you can usually pluck it out and re-trim if you need to do it.
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 02:48 PM
window replacement question qchawkfan General DIY Discussions 3 10-17-2010 04:21 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Window replacement Help (New Construction) gregt848 Building & Construction 3 10-18-2009 07:59 PM
Basement window replacement topher0524 Building & Construction 7 05-21-2009 03:59 PM
