Window Replacement: DIY'able? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-19-2014, 06:04 PM   #1
Rewards Points: 173
I'm looking to replace this 45+ year old 36x26" aluminum window with a new vinyl window. I've never replaced a window before and figure this is as good a window as any to replace.
The going to assume that the wire is not to code. It goes from the switch below to an exterior light. I also assume that the window framing is actually that 1" cedar that goes all the way around. Is a recip saw the best way to remove this?
This is what I'm working with:
View from inside:
View from outside:
New replacement window:
RCGA is offline   Reply With Quote
Old 06-19-2014, 06:22 PM   #2
Rewards Points: 14,312
What's outside for trim and siding?
Need a picture of the outside.
Wiring needs to rerun behind the sheetrock and stapled within 6" of the boxes.
Looks like you now have flat jamb windows.
What you bought is a new construction window.
Totally different style windows.
Old 06-19-2014, 06:23 PM   #3
Rewards Points: 173
2nd photo is from the outside
Old 06-19-2014, 07:46 PM   #4
Rewards Points: 144
That's not 1" cedar on the outside.It's brickmold.Looks like it was flush to the sheeting with the siding ran up to it and caulked.No wonder it all rotted.
Can't tell enough about the new window from the pic but think your going to have a hard time with it in this application.
mako1 is offline   Reply With Quote
Old 06-19-2014, 07:54 PM   #5
kwikfishron's Avatar
Rewards Points: 1,018
Did you order the correct size window? Or is this the one that's 2" short that you posted about in your other thread.
These little details are important.
kwikfishron is online now   Reply With Quote
Old 06-19-2014, 08:03 PM   #6
What does that matter? Cut the flanges off and it's a replacement window. I've had suppliers charge extra for no flanges. One minute to save $15.
Old 06-19-2014, 08:11 PM   #7
Rewards Points: 173
Sorry, yes, it's a 36x26 opening, and the the window is 36x24. I plan on building it up an extra 2"
Old 06-20-2014, 06:10 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
DIY'able to be certain if you have some carpentry skills.
Be sure to put in a drip cap.
Old 06-20-2014, 06:28 AM   #9
Rewards Points: 173
There's a drip cap above, will I also need one directly above the window?
Old 06-20-2014, 09:16 AM   #10
It will probably get damaged in removal and replacement of that brick mold and it might be in the way of the flange reset the new unit.
You don't need one above the window and above the brick mold. Just put one above the brick mold.
The Following User Says Thank You to Windows on Wash For This Useful Post:
kwikfishron (06-20-2014)
how to secure replacement casement window tambo Windows and Doors 5 08-10-2012 11:49 AM
Old replacement window jsfoltz Windows and Doors 1 08-26-2011 07:27 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 11:56 AM
