-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window Repair (http://www.diychatroom.com/f104/window-repair-97113/)
Willie5566 03-03-2011 09:37 AM
Window Repair
I have a dog that likes to go apesh*t on my windows anytime another animal goes by. Well he has finally done some damaged and I need to fix it. Here is what he has done to two of my windows:
http://i30.photobucket.com/albums/c3...6/05d4f8c5.jpg
I am pretty sure there are 2 panes of glass. The damage is only to the inside one. Is there a way to replace the inside pane? And is this a DIY job or do I need to look into a professional. I am a largely incompetent fixer-upper for the record.
tpolk 03-03-2011 10:02 AM
if you can find name of manufacturer just replace sash. If not take sash to window/glass company (or they may come to you depending on location) and they can probably replace glazing,call first. sometimes those electric shock blankets work for deterring or a shock collar set on low until he figures its better to let the truck go
HomeSealed 03-03-2011 12:54 PM
tpolk is right on... just one pane will not be able to be replaced, you'll either need an entire sash or IG unit.
Willie5566 03-03-2011 02:34 PM
So it sounds like it is not a good DIY job. Any idea what it would cost to repair 2 windows like this? Homesealed-It likes like you are in the business? What would fixing something like this run?
HomeSealed 03-03-2011 02:43 PM
If you were to purchase a new sash (you'd need to know the manufacturer first), they usually run like $50-$80 depending on brand. Getting it re-glazed should be roughly the same as long as you take it in somewhere. It could be do it yourself if you can figure out how to get the glass unit out of the sash. It looks like that window has an "interior" glazing bead, which is that half inch strip that goes around the perimeter of the glass. It typically snaps in and out. Then on the other side of the glass, there will be a bead of silicone that needs to be cut... Then you take the piece into a glass shop and have them make a new one . Bring it home and re-install the same way it came out.:thumbsup:
