#1 |
window r.o. two big
i have a new construction house and made an error on the r.o. on all the window r.o by 2 inches larger and taller than necessary.
would like to just add an aditional sill and a jack on one side to fill the gap. the windows are vinal. window size is 35.5 inches and my r.o is 38 inches also thought of mabee wraping the window r.o with a 3/4x6 inch wood to take up some of the space. the window flange on each side is 5/8 or so i think thank you matt Last edited by seaocean_180; 12-22-2012 at 11:46 PM. |
#2 |
window r.o. two big
Both ways would work, but using just 1, 2 X at the bottom and on one side would cut your work in 1/2 and there would be less chance of ending up with a nail between the pieces.
#3 |
STAFF
window r.o. two big
That would work, just don't add any to the bottom of your header, it will make all your windows too low.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
| The Following User Says Thank You to BigJim For This Useful Post: | Windows on Wash (12-24-2012) |
#4 |
AHH, SPANS!!!
window r.o. two big
make sure to add the filler the exact same on each window so they do sit in the openings differently etc... also, rework the housewrap/window wrap so that it is sealed tight after the new filler. filling in at the top might be the best way to do it and do not mess with the bottoms of the window plate/sill and wrap. new constructon window flange should be about 1- 1/8" surrounding entire window with the nail holes about 1/4" to 3/8" in from edge of flange..
if you do wrap with a 3/4" piece do not use plywood as it will not accept nails through the edge and into the separate plys... |
#5 |
window r.o. two big
ok thanx .. yes i was planning on using good plywood not osb.. or a good grade 1x6u so as to have a good surface. ...
todaly brain farted on the window r.o but everything else came out great.. lol. i gave the #the to the framers so guess this one on me thanx for the advice matt |
| Display Modes | |
| Installing a Replacement Vinyl window with brick mold | jlatulippe | Carpentry | 4 | 06-23-2011 03:05 PM |
| Defog window recap | greenmax | General Discussion | 4 | 05-07-2010 06:00 PM |
| help need to know how to replace windows wrapped in drywall | caide3 | Carpentry | 4 | 03-02-2010 01:41 PM |
| Problem with window and everything around it | malfunction | Building & Construction | 3 | 05-26-2009 06:11 PM |
