Window Question - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 09:48 PM   #1
Window question
Hi,
When installing a new construction window is it necessary to create a slope in the sill by using a piece of beveled materials such as cedar siding? If so, does that piece get fastened over or under the sill flashing tape?
markharmon is offline   Reply With Quote
Old 06-28-2013, 07:46 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
Most windows have the slope built into the sills these days, so no.
Old 06-28-2013, 10:27 AM   #3
Rewards Points: 31
Mark, I had this same dilemma with my windows. The sills were all flat. So I bought a product that gives the sill a sort of sloped sill. It's called tegratite, foam wedge put underneath the window, stapled to the sill stud framing. I used jeld-wen windows so i believe this is their product. Got it from a local supply house.
if you're going to put cedar siding on your sills to give a sloped sill, think about protecting it. otherwise check out sill pans or what i used.
Westbrook is offline   Reply With Quote
Old 06-28-2013, 02:20 PM   #4
The sills on the Jeld-Wen single hungs you just put in were flat?
There is a difference between a sill plate and a window sill.
If the water in inside and sitting on the sill plate, you have much bigger issues and will eventually get rot and moisture issues.
Old 06-28-2013, 05:48 PM   #5
Rewards Points: 31
Thumbs up
That is correct. No slope sill on the single hung. Didnt have sloped sill on previous window either. No rot after 43 years either.
I agree if you have moisture coming back in you will have long term issues. I tyvek'd visible studs where the window would be touching. Then put tegratite down,popped in window and flashed fins. Many rainstorms to date and no water leaks. I still have the stools off.
Mind you i did remove my siding as it was being replaced so it made window install much easier.
The Following User Says Thank You to Westbrook For This Useful Post:
Windows on Wash (06-28-2013)
Old 06-28-2013, 10:47 PM   #6
Wow, I can't believe what the rationale would be to put out a single hung with a flat sill but your install approach seems very solid so I am sure that is your saving grace.
Old 07-01-2013, 07:35 AM   #7
I'm talking about the rough opening sill not the actual window.
Old 07-01-2013, 07:57 AM   #8
Most guys don't slope the sill plate any longer. The flashings have gotten so good (flexible and what I prefer in the pan flashings) that it doesn't matter like it used to.
Window Replacement Mull Question ryanb4614 Windows and Doors 3 04-28-2013 06:13 PM
Header question - raising door and window RO enoll Building & Construction 10 05-04-2012 04:39 PM
2x6 window header question MoneyPit3 Building & Construction 12 04-02-2012 02:01 PM
window trim question blackestate Windows and Doors 22 09-21-2011 01:38 PM
Replacement window question on install... tidal9 Carpentry 1 08-16-2011 10:18 PM
