Window Quality Opinion Ineeded..... - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-30-2013, 05:45 PM   #1
Window Quality opinion ineeded.....
Ellison windows sold by ABC building supply; are they good windows for an average home renovation (not the highest end, but not the lowest)?
Sorry the question is a little vague, I'm still trying to figure out which questions to ask....
Thanks in advance,
DB
82ndpara is offline   Reply With Quote
Old 09-30-2013, 07:35 PM   #2
747
registered
747's Avatar
Rewards Points: 534
I have never heard of them. ABC Supply doesn't sell crap.
747 is offline   Reply With Quote
Old 09-30-2013, 07:48 PM   #3
....I think they're a subsidiary of Atrium Windows and Doors, out of Nirth Carolina....
DB
Old 09-30-2013, 07:58 PM   #4
*North*
Old 09-30-2013, 08:49 PM   #5
... forgot to add, I'm in New England....
Four replies, and I'm three of them (!)
I can't edit my posts for some reason........
or add a location....
DB
Old 10-04-2013, 04:44 AM   #6
747
registered
747's Avatar
Rewards Points: 534
I have heard of atrium. There good window. Like I said ABC supply carries good stuff. There not home chepo or blowes. They should also have some simonton's 5500.
Old 10-04-2013, 08:09 AM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Atrium cab be hit or miss across their lines. I'm not familiar with that particular line, but the most objective way to look at the product is the performance ratings. U value and air infiltration are most valuable IMO, along with shgc and dp. The top vinyl products are getting u values around .25-.26, and air infiltration of .01-.05cfm. The more run of the mill and lower end performers will barely hit a .30 u value, and will not even want to talk about AI, although their ratings will be +/- .20.... Every supply house including ABC has some solid stuff and some junk, so you want to look a little bit deeper
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 10-04-2013, 07:17 PM   #8
Thanks for the replies guys.... so these windows I was looking at; they sound a little inefficient for Western Massachusetts with the following ratings:
U factor .31,
SHGC .26,
"meets Energy Star ratings for North Central, South Central and Southern".
Keep in mind I don't know anything about what those ratings mean, I'm just comparing them to the previously stated ratings....
Thanks for the help....
DB
Old 10-04-2013, 07:42 PM   #9
747
registered
747's Avatar
Rewards Points: 534
Homesealed is a window expert. He will point you in the rite direction.
Old 10-12-2013, 12:56 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 848
U factor .31,
SHGC .26,
DB
Roger that.
HomeSealed is correct that Atrium is hit or miss. Not what most guys would consider to be a premium and you are 100% right that the energy numbers there are a bit light for Western MA.
You are Northern and that will not cut muster in your area to be E-star qualified.
uPVC window handle won't close window properly, how can I fix it? Epimenides Windows and Doors 4 02-10-2013 03:09 PM
flashing a vinyl window into stucco yhfwd05 Windows and Doors 0 01-28-2013 08:51 PM
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 09:39 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
