Window Pvc Trim - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-03-2013, 05:52 PM   #1
Rewards Points: 396
window pvc trim
when installing a new construction window can you simply install PVC trim directly over the nailing flange?
detroittigerfan is offline   Reply With Quote
Old 10-03-2013, 07:24 PM   #2
Rewards Points: 12,840
Why not buy new construction window with built in J moulding so there's no air or water leaks.
What do you consider as "PVC Trim". J moulding, vinyl lumber, ECT.? To answer your question, no, you need to apply self sticking window tape first.
Old 10-03-2013, 08:30 PM   #3
Rewards Points: 396
Ok yes I know about flashing. My question is regarding AZEC pvc trim. Do you fasten it over the flange?
Old 10-03-2013, 08:34 PM   #4
Framing Contractor
Rewards Points: 98
Yes. Just be sure that your nails don't hit the screws that you installed in the flange.
sixeightten is online now   Reply With Quote
Window trim over existing T-111? J Howard Remodeling 2 07-24-2012 11:49 AM
crown molding meets window trim sonofthetonsured Carpentry 13 03-19-2011 01:33 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Arched top window trim jelly Carpentry 5 07-05-2008 04:38 PM
locate a vendor for vinyl window pane trim bjr23 Remodeling 1 02-14-2005 12:59 AM
