Window Problems? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 08:41 PM   #1
Window Problems?
Is this damage from the windows? If so, how would I fix it?
Thanks!
Window Problems?-condo-2-.jpg.jpg   Window Problems?-condo-3-.jpg.jpg   Window Problems?-condo-1-.jpg.jpg   Window Problems?-condo-4-.jpg.jpg   Window Problems?-condo-5-.jpg.jpg
adamvanlin is offline   Reply With Quote
Old 10-25-2011, 11:44 PM   #2
43 years in construction
Arkitexas's Avatar
The damage appears to occurr above and below the windows so my impression is that the windows are not the source of the problem. Water is penetrating the masonry and driving the paint off the masonry. Is this wall solid masonry or is it a cavity wall?
If the wall is solid masonry it is very difficult to prevent this problem. Moisture finding its into the wall will migrate to the drier side which is typically the interior. If the interior surface is painted, the moisture will push off the paint as it migrates and reaches the interior surface. The best control is to not paint the interior surface or to use a pourous non sealing paint.
A proper masonry wall includes a 1" to 2" air cavity that is waterproofed at the interior surface. Moisture is expected (but not encouraged) to penetrate the exterior wythe but is stopped at the dampproofed surface of the interior wythe and weeped back to the exterior. Cavitywall masonry construction can be painted at the interior surface because the moisture level in the brick is stable and, for all practical purposes, does not migrate.
Regardless of the wall construction I suspect that the exterior surface of your wall is not protected from rain by a substantial eave or roof overhang.
One solution for your wall is to remove the paint from the interior wall surface. If you still want paint, use a non sealing paint that permits water vapor to pass, but not liquid water. Also investigate the exterior surfaces for possible sources of water penetration and correct.
Rick
Arkitexas is offline   Reply With Quote
Old 10-26-2011, 05:24 AM   #3
kwikfishron's Avatar
Rewards Points: 576
Post some pictures from the outside.
kwikfishron is offline   Reply With Quote
Old 10-26-2011, 07:11 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,558
Very common in this type of construction.
What does the roof look like? Leaks in this application are most often found above the window where the water enters the masonry and flows behind the wall.
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Stationery / Transom / Picture window ??? CoconutPete General DIY Discussions 7 02-04-2011 09:36 AM
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Window Leak: Flashing or Window? lverma Building & Construction 16 08-31-2010 12:46 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
