Window Ledge Material - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-25-2013, 04:11 PM   #1
Window ledge material
Hi there, I have some windows installed in my basement that look like this:
http://i.imgur.com/MvRgJjA.jpg
I have finished drywalling, and painting. But i'm not sure what to do with the window sill. Do I put drywall there? Or a jamb? Or something else? And what do I do with the edge that is touching the window? Some caulking?
Thanks!
ithm is offline   Reply With Quote
Old 05-25-2013, 04:20 PM   #2
Rewards Points: 12,818
That's up to you on how you want it to look.
Could be done with all 1X clear pine in the jambs and just picture framed with casing.
A wider piece of pine cut out wide enough to make a stool (the inside is called a stool, the outside is a sill) some pine in the jambs, an aprin then casing on three sides.
Windows on Wash (05-27-2013)
Old 05-25-2013, 06:34 PM   #3
OK, sounds good. What do I put in the gaps between the jamb and the window?
Old 05-25-2013, 11:15 PM   #4
Rewards Points: 2,202
Usually I build a plywood box the width needed. use shims on sides, bottom and top and nail into place. Then trim like a regular window.
mae-ling is offline   Reply With Quote
Old 05-25-2013, 11:16 PM   #5
Have also seen drywall on top and sides with wood (stained or painted) on the bottom and sticking out past, like the old windows.
Tags
finishing basement , jamb , windows and doors
flashing a vinyl window into stucco yhfwd05 Windows and Doors 0 01-28-2013 08:51 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
What to put on the window ledge?? ingeborgdot Drywall & Plaster 1 07-17-2010 11:09 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
What roofing material is right for me? Grumpy Roofing/Siding 0 07-07-2004 08:41 PM
