Window Leak Mystery - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 07:54 PM   #1
Window Leak Mystery
Hi. I'm Wags and new to the forum.
I purchased this house 2 years ago and noticed a small leak above one of the windows. I manipulated the gutters outside the window and added a little caulking and now only get moisture above the window. Today I was about to fill in above the window with some drywall compound and noticed that the area directly above my window is pretty much hollow and has rotten wood. The directly above the vinyl window is an aluminum flashing type material, then rotton wood, then some metal beam running the length of the window. I want to repair this but i'm concerned about moisture. Any ideas how to fix the problem. I've added several pictures for reference.
wagslick is offline   Reply With Quote
Old 05-02-2011, 09:41 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I'm sorry to say it --as I realize that this is a diy forum, but you have a can of worms there. I'd highly recommend that you hire a pro to come and remove the existing damaged areas and replace/ reflash properly. At minimum, some siding will need to be removed , drywall and framing replaced, new flashing properly installed, etc. It is nearly impossible to go step by step through what would be need based only on a few pics.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
kwikfishron (05-03-2011)
Old 05-03-2011, 04:58 AM   #3
kwikfishron's Avatar
Rewards Points: 586
Welcome to the forum wagslick.
I agree with HomeSealed you need a pro here. There is nothing in a tube that will solve this.
That’s a bad detail where the roof terminates into the corner of the window and has probably been a problem since the day it was built.
You need the right guy on this one, someone that can not only deal with the structural repairs but is also well versed on roofing and siding flashing details.
Stay away from any contractor that even mentions the word “caulking” as a possible solution.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
HomeSealed (05-03-2011), Tom Struble (05-03-2011)
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
Window & Door Air Leak bnovc General DIY Discussions 9 02-14-2010 09:09 AM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Cathedral Ceiling - mystery roof leak kamadus Roofing/Siding 4 05-06-2008 01:18 PM
