Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-13-2012, 09:31 PM   #1
Window leak!
I live in a cmu block house in Florida, and the window in my kids bedroom is leaks after a hard rain. I tore the drywall off beneath the window to find water stains on the block. I sprayed the window with a hose from outside and saw that the water was coming in from the side of the window. After removing the drywall below the window, I noticed that there is a gap below the window between the window farm frame and the block. What is the best way to stop the window from leaking? Can I fill the gap with great stuff? Should I remove the drywall around the entire window to check for more gaps?
Anything would help. Thank you
osaleh89 is offline   Reply With Quote
Old 11-13-2012, 09:33 PM   #2
Window leak!
Needs to be moved to windows.
Old 11-13-2012, 09:34 PM   #3
Window leak!
You can see it from the outside, we can not.
Post a picture.
Old 11-15-2012, 05:08 AM   #4
An old Tradesmen
Window leak!
Moved to Windows and Doors forum.
Old 11-15-2012, 07:12 AM   #5
Exterior Construction
Windows on Wash's Avatar
Window leak!
+1 to JoeCaption's comment.
Need to see a picture of the exterior and of the track of the window.
Old 11-17-2012, 12:09 PM   #6
AHH, SPANS!!!
Window leak!
it needs to be fixed from the outside not the inside as water starts from the outside when it rains and works its way to the inside of the structure...
hand drive is offline   Reply With Quote
Water Leakage Under Basement Window Well Slomarmoreno Plumbing 2 09-18-2012 06:40 PM
window leak c00rdb General Discussion 11 03-03-2010 07:29 AM
Window & Door Air Leak bnovc General Discussion 9 02-14-2010 10:09 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
