-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window leak! (http://www.diychatroom.com/f104/window-leak-163271/)
osaleh89 11-13-2012 08:31 PM
Window leak!
I live in a cmu block house in Florida, and the window in my kids bedroom is leaks after a hard rain. I tore the drywall off beneath the window to find water stains on the block. I sprayed the window with a hose from outside and saw that the water was coming in from the side of the window. After removing the drywall below the window, I noticed that there is a gap below the window between the window farm frame and the block. What is the best way to stop the window from leaking? Can I fill the gap with great stuff? Should I remove the drywall around the entire window to check for more gaps?
Anything would help. Thank you
joecaption 11-13-2012 08:33 PM
Needs to be moved to windows.
joecaption 11-13-2012 08:34 PM
You can see it from the outside, we can not.
Post a picture.
beenthere 11-15-2012 04:08 AM
Moved to Windows and Doors forum.
Windows on Wash 11-15-2012 06:12 AM
+1 to JoeCaption's comment.
Need to see a picture of the exterior and of the track of the window.
hand drive 11-17-2012 11:09 AM
it needs to be fixed from the outside not the inside as water starts from the outside when it rains and works its way to the inside of the structure...
