Window J Channel - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 07:53 AM   #1
Rewards Points: 396
Window j channel
I purchased a window with an integrated j channel for vinyl siding. I was planning on having azec trim around the window with j channel on the outside of that to accept the siding. Is it possible to remove the J channel from the window so I can do this?
detroittigerfan is offline   Reply With Quote
Old 08-18-2013, 08:28 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,238
Post up a picture.
If it is extruded as part of the frame...its not worth it and you are going to potentially make a mess of it.
If it is a clip in design, I could possibly be removed if it is not part of the nailing flange assembly.
Old 08-18-2013, 08:53 AM   #3
Rewards Points: 396
Originally Posted by Windows on Wash View Post
Post up a picture.
Its part of the frame. So, should I just but the azec up to the channel then?
Old 08-19-2013, 07:44 AM   #4
Rewards Points: 396
Post up a picture.
Old 08-19-2013, 09:43 AM   #5
That will be fine.
I would still put a drip cap over the trim or window (depending on how the reveal is).
Old 08-19-2013, 10:29 AM   #6
Rewards Points: 396
That will be fine.
what do you mean how the reveal is?
Old 09-01-2013, 06:55 AM   #7
Its a term to describe something about the window, but I am not sure! Hopefully someone will come in and educate us newbs!
VtecGSR95 is offline   Reply With Quote
Old 09-02-2013, 01:07 PM   #8
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,124
what type of siding are you having installed. the other problem with putting azec up to the window if its already j`d out is that you wont have a proper edge to caulk the azec to around the window. because of that water is more likely to get behind the triim
woodworkbykirk is offline   Reply With Quote
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
window performance question renbelle Building & Construction 4 10-06-2010 02:25 PM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
