Window Insulation Panels - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 09:05 PM   #1
Rewards Points: 16
In the master bedroom of my house I have 2 double-hung windows side by side with a large arch window on top. These windows leak a lot of air and with the 12 foot ceiling in the room it gets cold in there while the rest of the upstairs is warm. I've looked into replacing the windows but it's very expensive and I don't have the cash for it right now. So for this coming winter I was thinking about building some "window insulation panels" like what's described on this page: http://www.arttec.net/Thermal-Windows/index.html.
I don't have a picture of my actual window(s) handy but it's similar to the one on this page: http://www.123rf.com/photo_2833058_arched-window.html
First, does anybody have any experience with using the window panels and do they make any difference?
Second, the window panel would only go over the 2 double-hung windows, not over the arch. The issue I have is there's no frame on the top between the double-hungs and the arch, so there's nothing for the top of the window panel to press up against. Could this still work? I was thinking about putting some weather stripping on the inside, pressing up against the top of the double-hungs to block the air.
mikelbeck is offline   Reply With Quote
Old 11-26-2011, 12:12 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,044
Internal storm windows do work very well when they are air tight.
You created a secondary trapped air space (if they are air tight) which functions as an insulator and making the opening air tight will eliminate the bulk losses.
You could easily attach a piece of weatherstripping and foam to the top of the internal storm to create that seal across the mullion between the arch top and the twin double hung.
The Following User Says Thank You to Windows on Wash For This Useful Post:
mikelbeck (11-26-2011)
Old 11-26-2011, 06:49 PM   #3
Rewards Points: 16
Yeah, that's what I was thinking.
The bottom part of the window (the two windows side by side) is at least 6 feet high and at least that wide, maybe more - I'd have to measure it. Would there be any issue building the panel this large or would I be better off making two panels?
Old 11-26-2011, 06:53 PM   #4
Single panel is fine. If glass, it will need to be tempered if in the tub area.
You might want to consider acrylic for safety.
Old 11-26-2011, 06:55 PM   #5
Rewards Points: 16
I'm planning on using the shrink film like what's mentioned in this article: http://www.arttec.net/Thermal-Windows/index.html
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
installing insulation in aluminium window interior stefania Building & Construction 2 01-18-2011 03:37 PM
How do I *not* mangle polyiso panels when I pull vinyl siding for insulation blow? steveel Building & Construction 5 10-10-2010 09:02 PM
Shrink film window insulation, no kit EscarHolmez General DIY Discussions 3 12-28-2008 12:05 PM
dormer window insulation wlm-21 Building & Construction 2 02-13-2007 04:04 PM
