Window Installation/plywood/foam Board/tyvek - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-18-2011, 01:48 PM   #1
Window installation/plywood/foam board/tyvek
We are installing new vinyl windows in a 100+ year-old-house. We are leaving on the wood underlayment where possible or replacing with plywood as needed. We are adding 1/4 inch foam board for extra insulation and then tyvek to seal it all. When we started putting the windows in, we did not have the 1/4 inch foam board, hence did not put it behind the windows - only sealer tape and tyvek as appropriate. Now we are installing a patio door and my husband is putting the 1/4 inch foam behind the flange of the door. The flange is for the vinyl siding and I believe it will accommodate the 1/4 inch pink foam as well (plus sealer tape and tyvek properly installed. Our question is - should the door and windows be installed over the 1/4 inch pink foam or should it be installed after the windows are in and put in the flange area??? Then, of course, properly seal all with sealing tape, tyvek, etc., etc.
mdix is offline   Reply With Quote
Old 08-18-2011, 04:54 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
ok,the drainage plane starts just under the flanges,the flashing or membrane needs to over lap the foam allowing water to drain away on top of the foam instead of behind it at the bottom of any openings
the flanges don't necessarily need to be built out the foam thickness as long as this drainage detail is followed
hopefully this pic can give you an idea
you need to be very careful you don't inadvertently cut the tyvek when fitting the foam
Window installation/plywood/foam board/tyvek-1027101245.jpg
Tom Struble is offline   Reply With Quote
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Defog window recap greenmax General DIY Discussions 4 05-07-2010 05:00 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
