-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window Installation (http://www.diychatroom.com/f104/window-installation-160454/)
ssummerfield13 10-18-2012 07:02 AM
Window Installation
I want to put two new 2'x5' double hung windows where there are no windows now. Family room is dark and want to add light, so new hole needs to be cut in the wall of my house to put new windows in
ssummerfield13 10-18-2012 07:05 AM
new windows
I want to install 2 windows on either side of my fireplace, but there are no existing windows there now. Can you give me a rough estimate on what I could mexpect to pay a contractor to do these for me. Also, if I wanted a radius window on top what extra cost might be added? Thank you
HomeSealed 10-18-2012 08:31 AM
That is definitely doable, however you could see an amazingly wide scope of pricing based on different factors: type and quality of window, existing interior and exterior wall cladding, amount of finishing to be done by installer (ie: finishig drywall, painting, installation of trim stained or unstained), any potential issues in the way like electrical wiring etc... and the list could go on for a while. As a complete guesstimate for a decent quality window "cut-in" I'd say somewhere between $1200-$3500 per window. I know that is a wide range, but there are soooo many variables.
Windows on Wash 10-18-2012 09:54 AM
+1
Could be from moderately expensive to really expensive. There is zero way to tell without a whole bunch more information. You might as well punch a couple of holes in the drywall to see if this anything in the wall that would require re-routing unless you otherwise know or can tell from the room and what is on either side.
Davejss 10-18-2012 09:10 PM
I'll do it for $15,000.00 plus materials. Also, you'll have to provide transportation from where I live to where ever you live. Oh, and you'll also have to spring for a round of golf and good bottle of scotch.
If you promise to read the sticky about not asking for prices I'll knock off ten percent.
ssummerfield13 10-18-2012 10:42 PM
You are quite the comedian. I am so glad you were willing to offer the advice. I'm betting you nickname is douche bag Dave.
ssummerfield13 10-18-2012 10:45 PM
Nothing in the walls, drywall inside, vinyl siding outside, j-channels on the windows, vinyl either double hung or casement, not sure yet. Thank you for your reply, helpful even with the wide range.
HomeSealed 10-19-2012 06:07 AM
Sounds pretty simple and straightforward so you would hope that it would come in on the lower end of the spectrum. Best thing to do at this point is get a couple quotes.:)
kwikfishron 10-19-2012 06:25 AM
199 Attachment(s)
Another thing is that any time you cut a new hole into a structure you will likely need a permit.
Is this a load bearing wall? If so you’ll need a properly sized header and will likely have to open up more of the wall than if it wasn’t.
mae-ling 10-19-2012 11:09 AM
LOcal quotes are the only way to know.
ssummerfield13 10-20-2012 08:09 AM
Thank you very much, shame you're not in NJ! THnaks again.
HomeSealed 10-20-2012 08:32 AM
I may not be, but I do know a couple really good guys that serve different parts of NJ. Paul at AGM serves the northern part and Wayne at Taylor and Young is further south. I don't know if either serves your exact area, but I couldn't recommend the two of them more highly when it comes to window installations.
ddawg16 10-20-2012 08:45 AM
Summer....just so you understand, asking prices here is a bit of a sore point....hence, you (and anyone else who asks about price) is typically going to get a less than desirable answer....
So....as the others have said....call and get quotes.....
Me? I would just do it myself....sounds like a fun project.....and you could get all the info you need from this site (just don't ask how much it cost)
Braddiy 10-27-2012 12:22 PM
I am getting replacement windows installed as we speak
Replacing my original wood windows with vinyl windows and also getting a window bricked in because need more space for kitchen cupboards. I live in canada so prices are very different i would imagine. to brick in a window and add new sill and steele lentil above window (area is 5ft by 5ft) the cost was $1000.00 not including the window. i realise this is opposite of your making hole but i think cost would be similar. it took one day to do all work except for the install of new window another few hours.
My advise is to get as many quotes as possible (i got 5 quotes) before deciding. oh and be prepared for quite a mess to clean up as cutting walls is messy.
I also bought all materials at cost once i picked my contractor probably saved $200.00.
Good luck!
Braddiy 10-27-2012 12:26 PM
see my photos of bricking in window, cheers
see my photos in photo section
Good luck!
