Window Install Help - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-08-2012, 10:06 AM   #1
Window install help
Just finished re framing my wall and had two questions:
Is there a better way to cut out the opening besides a recp saw? I completed the first one but it was not a flush cut. I went back and cleared it up but thought there has to be an easier way. Or dies it even matter as long as the window fits in the opening?
Second
House wrap, I see the water membrane in shows is directly on the sheathing, or should I put this house wrap up next to the window or place it under the membrane before prepping the window with the felt and membrane? To me I would think membrane directly on sheathing is better because if house wrap loosens your wall would be exposed.
Any thoughts?
bemgolf is offline   Reply With Quote
Old 06-08-2012, 10:22 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Circular saw works well too.
While Install Master guidelines show the house wrap to inside then membrane...I tend to agree with you.
I flash right to the sheathing and have the house wrap to the outside of that.
Old 06-08-2012, 11:22 AM   #3
So it would be stapled right next to the membrane or shoud I overlap it?
Old 06-08-2012, 12:58 PM   #4
Overlap and tyvek tape it.
The install masters specify an upside down "Y" cut.
There are a ton of videos on it.
Old 06-08-2012, 08:11 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
it does matter especially at the bottom you don't want any lippage that could trap water,some guys like Loneframer use a router
as far as the flashing,in coastal areas the thinking is set the unit to the sheathing and start the wrb about an inch or 2 away from the flange
then apply the tape,the thinking being should water get under the wrb the tape to sheathing will keep it from getting under the flange
the thing that i think is very important but seldom seen it to use a roller to make sure the S.A. is in firm contact
i use a small steel hand roller but i think i'm going to have to get a silicone wheeled J roller
Tom Struble is offline   Reply With Quote
The Following User Says Thank You to Tom Struble For This Useful Post:
Windows on Wash (06-09-2012)
Old 06-09-2012, 06:28 AM   #6
Tom,
That stuff is a real PITB to stick down in the winter too. I have the guys keep it in a hot box before application.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (06-09-2012)
Old 06-09-2012, 12:25 PM   #7
here's mine
Old 06-10-2012, 01:14 AM   #8
That is pretty much ours as well.
Replacement window install question. joshg3p0 Windows and Doors 5 06-05-2012 10:32 PM
Help! Window AC install issues knotquiteawake Appliances 5 05-01-2012 09:42 PM
Help with new construction window install pac127 Windows and Doors 1 09-26-2011 08:36 AM
Window install Cossack Building & Construction 1 08-15-2010 11:34 AM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 09:34 AM
