Window Install - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-22-2013, 09:57 PM   #1
Rewards Points: 37
Window Install
Installed a vinyl new construction window yesterday. It slides horizontally. The directions stated I needed a minimum 1/2" clearance around the frame, and then use shims. Well I put it in, a little tight, pretty much zero clearance.
It operates smoothly and closes squarely. Will i run into problems down the road because of no clearance?
The rough opening was existing, not a new wall. Used a new construction window because it works better with my new sheathing and siding.
Thanks.
RodBarney is offline   Reply With Quote
Old 06-22-2013, 10:45 PM   #2
Roofmaster
Rewards Points: 2,210
Thanks.
Not in San Diego!
Old 06-22-2013, 11:01 PM   #3
Rewards Points: 37
OK. Please explain...
Old 06-23-2013, 11:06 AM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,332
if it operates smoothly youll be fine as long as the house doesnt settle which coiuld cause it to bind. .other than the only thing will be you dont have any space for spray foam insulation between the framing and the window
woodworkbykirk is online now   Reply With Quote
Old 06-23-2013, 01:44 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
He is probably referring to the relatively stable moisture content and temperatures in San Diego.
+1
If the house is pretty stable at this point, you should be fine.
If the gap is too tight for window foam, caulk it well.
Old 06-24-2013, 11:19 PM   #6
Rewards Points: 37
OK. Thanks for the help guys. I did caulk the window well. Do you know what San Diego means in German?
Old 06-26-2013, 12:46 AM   #7
Registered User
Rewards Points: 526
They say the newer vinyl doesn't expand much like older large, dark colored ones without the welded corner miters.... though you did lose the warranty...
Gary
Old 06-26-2013, 10:08 AM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
When you say ZERO clearance do you mean like 1/8" or so around all sides, or like you had to tap it in with a mallet? If the former, you will likely be just fine as replacements are installed to those specs all the time, and when you shim a window in tight it doesn't exactly allow for a ton of movement anyway. They main thing is that it is square, well sealed around the frame, and flashed properly to the exterior. I wouldn't worry too much about voiding the warranty unless this individual issue actually causes a problem down the road.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Out of square window how best to install miamicuse Windows and Doors 5 04-19-2013 01:34 PM
Replacement window install question. joshg3p0 Windows and Doors 5 06-05-2012 10:32 PM
Help with new construction window install pac127 Windows and Doors 1 09-26-2011 08:36 AM
Window install Cossack Building & Construction 1 08-15-2010 11:34 AM
Window Install Question Tom5151 Building & Construction 1 09-29-2009 09:34 AM
