Window Height ? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-08-2012, 11:04 AM   #1
Rewards Points: 236
window height ?
what is the current thinking on how close a typical window should be from the floor ?
i have single hungs and they are about 22" from the floor. so placing much of anything in front of it, is not going to be a good idea.
thanx
btw, i am thinking about getting sliding windows to replace these worn out units.
Fix'n it is offline   Reply With Quote
Old 04-08-2012, 11:16 AM   #2
Rewards Points: 13,694
In my book it says anything below 24 from the floor it needs to be tempered glass. I also heard from my inspector it may be changed to 36".
I just hate single hung and sliding windows. A double hung is so much easyer to clean. The sashes just snap out and tip in for cleaning.
Old 04-08-2012, 11:10 PM   #3
Registered User
Rewards Points: 5,514
http://publicecodes.citation.com/ico...008_par006.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
HomeSealed (04-10-2012)
Old 04-09-2012, 07:00 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,596
Originally Posted by GBR in WA View Post
Gary's is more technically accurate but I have always sent this link to customers.
Seems a bit easier to read.
http://dealer.milgard.com/egress--.htm
Windows that close to the floor is fine but even though it may not be code required (tempered glass), it is a cheap investment in safety.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Gary in WA (04-10-2012), HomeSealed (04-10-2012)
Old 04-10-2012, 08:23 AM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
good links.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-10-2012, 09:56 PM   #6
Rewards Points: 236
these windows are close to, if not, 100 years old = painted shut.
i am thinking about sliders. but idk yet.
the reason i ask about the height, is furniture placement. my last place, i had dressers in front of the windows. so i guess i will just go with that.
Old 04-14-2012, 03:34 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,200
locally no window can be less than 18" off of the floor when grade outside is more than 24" below the sil of the window.. anything less then either a saftery bar must be infront of it or the operator is up top on it
woodworkbykirk is offline   Reply With Quote
Window treatment options? bokeh Interior Decorating 13 07-04-2011 12:30 PM
Floor to window sill height shannyn Building & Construction 0 06-26-2011 07:37 PM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
