Window Handle/frame Problem - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-29-2013, 12:01 PM   #1
Window handle/frame problem
We have a window handle which is screwed into the frame, but a small piece of the plastic holding one of the screws in place has broken off (the screw on the right).
Because the screw and therefore handle aren't held completely in place, the window is hard to open and close.
Do I need to replace the frame/window? Or would it be possible to repair the broken segment? Recommendations are much appreciated.
Cindy_Home is offline   Reply With Quote
Old 07-29-2013, 12:29 PM   #2
Rewards Points: 14,026
Not pretty but cheaper then a whole new sash, try what's called a fender washer, may also need a longer screw.
A fender washer has a small hole but a larger outside diameter.
Old 07-29-2013, 03:04 PM   #3
Sounds like a good idea, we'll give it a try. Thanks very much.
uPVC window handle won't close window properly, how can I fix it? Epimenides Windows and Doors 4 02-10-2013 02:09 PM
trapazoid window problem snafu999 Windows and Doors 3 06-06-2012 06:39 AM
How do I remodel a problem window halfway into shower stall? vintageQN Building & Construction 6 10-02-2011 03:16 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
