Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 12-01-2012, 01:48 PM   #1
Window Glass replacement. Manufacturer?
My double pane glass seems to have broken the seal & I will need to replace the glass. I looked around for the manufacturer's name but nothing is mentioned on the windows. I only found this sticker. Can someone please help me identify the manufacturer from this sticker.
Or suggest where I can get replacement glass in North Chicago Land area.
thinkfuture is offline   Reply With Quote
Old 12-01-2012, 03:40 PM   #2
It looks like that unit was made or sold through www.thermalindustries.com/ . I printed the tag and will see if I can find out on Monday. Check the center of the top frame of a double hung for a sticker; it should be covered by the back sash so you will need to open the top window to see it.
When it comes to replacement it truly comes down to the over all glass thickness and how many pains of glass it is. The window will most likely have argon, but if not it will have a shot of nitrogen to keep down water vapor forming between the glass.
There are primary 2 different thickness of glass. The older unites were around half inch thickness and I think the newer standard is closer to an inch (like 7/8). If I remember I’ll find out Monday for you.
The glass is put into the sashes with a bead of silicon to the insides and on the outside there is a molding that will pop out. There are some odd deigns on how the molding snaps in so good luck. The glass will pop out with a putty knife run between the glass and the frame, but unless your good you will crack the glass.
Any local window manufacture should be able to replace the glass in about an hour unless it is tempered.
I'll see what I can find out on Monday and post it for you.
If you need more info or more help send me a PM because I don't always check this site.
1950home is offline   Reply With Quote
Old 12-01-2012, 05:14 PM   #3
Anything etched in the glass? Usually lower righht corner of the glass. Check for any symbols or company logos on the locks or operators.
mknasa dad is offline   Reply With Quote
Old 12-03-2012, 09:10 AM   #4
Exterior Construction
Windows on Wash's Avatar
Its a TI window.
Call them and they will walk you through the warranty process, if there is any.
Hurd window replacement glass Linda Neveaux Windows and Doors 4 04-02-2012 08:32 AM
looking for some help picking a replacement window: prm2003 Windows and Doors 21 03-22-2012 10:07 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 04:33 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
