-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Window Frames Pulling Away from Wall (http://www.diychatroom.com/f104/window-frames-pulling-away-wall-171431/)
Sunny3301 02-09-2013 01:13 AM
I am wondering what to use to seal air leaks around window frames. Most of the articles I've found addressed sealing them from the outside of the home. But I need to do it from the inside because the actual wooden frames have pulled away from the wall (sheetrock) over the years. Gaps are only 1/8" - 1/4" wide. I assume I should use caulk, but which type? I don't know how to "finish" the project so ugly white caulk isn't visible each place I've done. Do I simply paint it afterwards? If so, what type of caulk is best? Thanks
gregzoll 02-09-2013 01:26 AM
Really need pictures. As for your question, no caulk is not going to fix the problem that you have.
