Window Flashing - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 12:45 PM   #1
Rewards Points: 396
window flashing
I read an article stating that when applying flashing tape you should not install it over the bottom nailing flange just the head and sides. Is this true? if so, how can you seal the bottom nails heads then?
detroittigerfan is offline   Reply With Quote
Old 08-12-2013, 09:31 AM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The bottom nailheads don't need to be sealed over. I suppose you could put a blob of caulk on each one if you want....
Ideally I like to have the flashing tape under the flange on the bottom. It will then seal to the nail shanks.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 08-12-2013, 09:39 AM   #3
kwikfishron's Avatar
Rewards Points: 186
That is correct, if you tape the bottom flange and water does make it to the sill it will trapped. I the weather barrier and sill flashing are installed correctly then any water that may get to sill should be able drain to the outside of the WB.
kwikfishron is online now   Reply With Quote
Window flashing question markharmon Building & Construction 18 06-18-2013 05:59 PM
General window install questions miamicuse Windows and Doors 9 04-23-2013 09:05 PM
window flashing over tar paper olsonjh Windows and Doors 10 09-11-2012 08:14 AM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
window flashing hitmehhh Building & Construction 27 08-24-2010 08:46 AM
