Window Drip Cap For PVC Trimboard - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By joecaption
  • 1 Post By Yodaman
Old 03-20-2017, 08:17 AM   #1
Rewards Points: 8
Window Drip Cap for PVC Trimboard
Hi Everyone,
I am installing clapboard siding with PVC trim board around windows and doors. My wall structures looks like:
Sheathing
House Wrap
Self Adhesive Window Flashing
1.5" Foam
3/4" rainscreen
Siding
Most of what I am reading is that a drip cap is still required but most of the homes I see near by that have PVC trim and clapboard do not appear to have any drip caps installed?
Thoughts?
JTD83 is offline   Reply With Quote
Old 03-20-2017, 08:55 AM   #2
Rewards Points: 13,732
Re: Window Drip Cap for PVC Trimboard
I'd still want a Z mold and a kick out strip installed above the trim to tip the siding out slightly so the water runs past the trim not behind it.
Yodaman likes this.
Old 03-20-2017, 02:06 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
+1
Drip cap above the trim.
Old 03-20-2017, 06:29 PM   #4
Rewards Points: 8
Thanks for the replies, just to be 100% clear, your advice doesn't change adding that the windows are new construction vinyl with caulked nailing flange (except bottom).
I assume you would recommend the same but i have seen others talking about this situation and said a drip cap was not required.
Old 03-20-2017, 06:44 PM   #5
Rewards Points: 8
To be clear, the Z mold would be between foam and exterior? If there was no foam, i know it would be integrated with WRB but assuming because of the 1.5" of foam, it would be installed after foam?
Old 03-20-2017, 07:09 PM   #6
Property Mgt/Maint
Rewards Points: 1,258
The top leg of the Z flash, or drip cap should tuck up underneath your house wrap
Windows on Wash likes this.
Yodaman is offline   Reply With Quote
Old 03-27-2017, 11:21 AM   #7
Rewards Points: 8
I am assuming that drip caps are generally custom bent for walls with foam? I cant seem to find a pre-made drip cap wide enough for my application to reach through foam to get behind WRB.
Old 03-27-2017, 11:48 AM   #8
Property Mgt/Maint
Yes, they are generally made on site with a brake. You might consider renting one for a day and bending up all the flashing that need.
flashing a vinyl window into stucco yhfwd05 Windows and Doors 0 01-28-2013 07:51 PM
Rotted window frame bottom: Do I need to replace the whole window? Ginette Building & Construction 4 09-15-2010 08:52 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 09:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
