Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 09-03-2011, 06:32 PM   #1
Window cladding leak.
I have a window that, when is hit with driven-rain, 'wicks' water down under the bottom of vinyl. It then is pushed back up on the inside and manifests itself just above the formed window pull.
BTW, this is on the bottom sash. Is this possibly just seeking a pressure differential?
Basically, the bottom is U-shaped. Comes in at the top of "U" outside, rolls under the glass, and comes back up and out on top of "U" inside.
Brown Dog is offline   Reply With Quote
Old 09-03-2011, 07:29 PM   #2
Pro Slate Roofer
tinner666's Avatar
I've dedicated a few pages to the issue.
http://www.albertsroofing.com/Window%20Flashing.htm
Frank
tinner666 is offline   Reply With Quote
Old 09-03-2011, 10:17 PM   #3
Tom Struble's Avatar
can you see any weep holes in the bottom of the window frame?
take and post some pics if you can
Tom Struble is offline   Reply With Quote
Old 09-07-2011, 11:47 AM   #4
Exterior Construction
Windows on Wash's Avatar
+1 for pictures.
Removing a window for painting... JJDoherty General Discussion 6 08-31-2010 09:39 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
Window & Door Air Leak bnovc General Discussion 9 02-14-2010 10:09 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
