Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-14-2013, 07:44 PM   #1
window capping DIY
How can I put window caps on my outside windows myself.
Thanks Bill
GabbyAbby is offline   Reply With Quote
Old 01-14-2013, 08:40 PM   #2
Civil Engineer
window capping DIY
I built my window caps using copper sheet and a home made brake. I found the information in an old issue of Fine Homebuilding, you may be able to do a search of back issues. Very nice discussion about how to bend copper, solder it, and form caps for windows and doors. Course if you don't like copper, you could do the same thing with lead, tin or aluminum.
Old 01-14-2013, 08:51 PM   #3
Windows & Remodeling
HomeSealed's Avatar
window capping DIY
Step one: rent brake and learn how to use it. Step two: learn how to flash an opening properly so that it sheds water outward rather than inward. Many professionals have a difficult time with step two.
Alternatively, you could just hire someone to do that part of the install if you feel comfortable doing the window install (assuming that you are replacing windows, not just wrapping them).
HomeSealed is offline   Reply With Quote
Old 01-14-2013, 09:05 PM   #4
window capping DIY
I'd strongly suggest hiring this one out.
Done wrong and it will add to the leaks and look like poop.
Going to need a brake, snips, seamers, a Pea shooter, coil stock nails.
A roll of coil stock, I'd strongly suggest using PVC coil not just painted stock for a longer lasting finish.
What type windows do you have?
Got a picture of the window outside?
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
New replacement window problems iminaquagmire Windows and Doors 7 11-12-2011 12:56 AM
Old Bay Window, lack of support... ogrenjr Building & Construction 6 03-04-2010 10:30 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
