Window In Brick Siding - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 08:53 AM   #1
Rewards Points: 396
window in brick siding
When you install a window in an opening that has brick there is going to be a small gap between the window and the brick siding, correct? What is normally done to conceal that gap?
detroittigerfan is offline   Reply With Quote
Old 08-12-2013, 08:33 AM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sometimes yes, sometimes no. Brickmold trim fills the gap.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 08-12-2013, 09:12 AM   #3
Haverhill Trade 1965
If there is a gap I would seal it with an elastomeric sealant. Lexcel is one brand, and H D sells one too but I can't remember the name. It is very elastic and adheres to dissimilar materials, and will reseal if cut. Check the label, if it is elastomeric it is flammable. It is not silicone or latex. Not cheap, about $7 a tube.
Duckweather is offline   Reply With Quote
Old 08-12-2013, 10:57 AM   #4
Rewards Points: 396
What about aluminum trim or wrapping with aluminum coil?
Old 08-12-2013, 03:05 PM   #5
Home Performance
HomeSealed's Avatar
Rewards Points: 712
The brickmold or wood trim is the base which can then be wrapped with aluminum. In some circumstances the trim can be "faked" with no wood under it, but I generally like to have something underneath. At the very least, it gives you something to nail the metal to.
www.HomeSealed.com
Old 08-13-2013, 07:29 AM   #6
Rewards Points: 396
Do you sometimes have to fasten wood to the brick and then wrap it?
Old 08-13-2013, 03:28 PM   #7
Is there wood framing inside the brick opening, or are you just putting a window into a brick opening?
Old 08-13-2013, 03:40 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Rarely. Normally it is fastened to the rough opening.
www.HomeSealed.com
Old 08-13-2013, 04:19 PM   #9
Rewards Points: 396
[QUOTE=HomeSealed;1228853]Rarely. Normally it is fastened to the rough opening.[/QUOTE
There is an air space between framing of the house and the brick dont you need a piece of wood stock to cover that gap then you can wrap with aluminum?
Old 08-13-2013, 04:21 PM   #10
Rewards Points: 396
When would you have a brick opening with no wood framing behind it?
Old 08-13-2013, 05:29 PM   #11
If it was a brick wall not just a veneer.
Old 08-13-2013, 05:31 PM   #12
Rewards Points: 396
all houses that have brick is just a siding with wood framing behind it. The brick serves no structural purpose.
Old 08-15-2013, 05:45 PM   #13
We have many houses here in New England that have a full 8" brick wall with some furring or strapping on the inside to fasten plaster lath to. Probably into the early 1900's. You can find things fastened directly to the bricks with "whistlers" like a backwards springy metal cloths pin set in the mortar joints that nails are driven into. Even inside trim where the masonry was exposed or plastered.
The Following 2 Users Say Thank You to Duckweather For This Useful Post:
HomeSealed (08-16-2013), Windows on Wash (08-16-2013)
Old 08-16-2013, 07:27 AM   #14
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1 to duck weathers comment.
www.HomeSealed.com
Old 08-21-2013, 10:00 AM   #15
Rewards Points: 87
Maybe in modern home construction, where the mantra seems to be "siding, siding, siding," but any house from the 60s (maybe even 70s) and earlier has a good chance of having structural brick walls.
huesmann is offline   Reply With Quote
Exterior Finishing of a New Constr. Window Install (siding etc.) DefyInertia Windows and Doors 3 04-10-2012 11:29 PM
Sun warps siding (window magnifies) RainWaterEyes Building & Construction 9 09-01-2011 12:36 AM
Drip Cap necessary if there's no siding above window? toolingaround Building & Construction 7 10-25-2010 08:53 PM
Window Flashing with Metal Siding vtboy51 Building & Construction 5 02-15-2010 05:00 PM
? RE:Replacing exterior brick with LP lap siding on a poured concrete foundation Greg D Building & Construction 0 11-26-2009 07:49 PM
