Will The Noise Reduce If Installiing Drywall On A Glassless Window? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-21-2011, 08:06 PM   #1
Will the noise reduce if installiing drywall on a glassless window?
What I am trying to do is reduce noise people conversations outside my window. So what I would do is take the glass out from the window and put drywall, called quietrock, and glue it with green glue and screw it also.
Will that reduce at least some noise from outside?
baby327nd is offline   Reply With Quote
Old 03-21-2011, 08:17 PM   #2
DIY staff
Rewards Points: 7,174
Why remove the glass? Just use double faced tape and stuck it to the glass.
A much better solution might be to make sound deadening shutters.
Motels use very thick curtains to deaden outside noises.
I'm just tossing out ideas---Mike---
Old 03-21-2011, 08:55 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
This would be an excellent solution to reduce noise in a trailer park.... Just make sure that you use some duct tape in there somehow.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Would a drop ceiling reduce percussive walking noise from neibor above? fredonian Building & Construction 8 05-19-2009 03:23 PM
Soundproof Windows BlueJello General DIY Discussions 3 11-30-2007 05:34 PM
Drywall bull nose around a window dstolese Building & Construction 2 10-10-2007 10:43 AM
What makes a quiet window? Badfish740 Building & Construction 8 09-30-2007 10:22 AM
