Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 03-12-2011, 11:24 PM   #1
Which will be more cost effective?
Ordering a custom sized 32x76 door or opening up the hole (which will include cutting back siding) to fit a 32x80.
Not sure the upcharge on custom sized doors. Was thinking about Therma Tru but if anyone has any other cost effective suggestions, I'm all ears.
manofmany is offline   Reply With Quote
Old 03-13-2011, 07:41 AM   #2
Super Moderator
A lot depends on how the header above the door is built--and the outside door trim.
And if you will be doing the work yourself.
I would most likely enlarge the opening--if the outside work isn't to extensive.
Post a picture inside and outside,if you can.
Old 03-13-2011, 08:24 AM   #3
Yep. a pic would help. The rough opening needed for a 32x80 door is 34x84 If you have that(height could be slightly less), you can install the standard door. To raise the header requires a bit of structural rearranging and removing inside and outside wall coverings. It can be done without removing one side, but gets tricky for a casual DIY.
Cost effective home plan abbey1 Building & Construction 8 08-27-2010 01:11 PM
most cost effective house plan ugabulldog Building & Construction 12 01-03-2010 02:10 PM
Cost Effective Design dreamhome Building & Construction 8 07-04-2007 08:59 PM
Is adding insulation in attic cost effective? AllGoNoShow Building & Construction 1 12-05-2006 12:31 PM
