Will Decorative Window Film Stick On A Bathroom Window? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-02-2013, 05:39 PM   #1
Will decorative window film stick on a bathroom window?
I would like to put a decorative window film onto a flat surfaced plate glass window in my shower...was just wondering if the moisture would be a problem. Thanks for any help.
trickshot63 is offline   Reply With Quote
Old 04-02-2013, 06:30 PM   #2
Rewards Points: 13,282
Best thing you can do is just get rid of the window if it's in a wet area.
A film may or may not stick, there cheap enough to give it a try.
Old 04-02-2013, 07:39 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,882
If you clean the surface and prep it, the ones I have seen stick for a good, long while.
Old 04-02-2013, 08:16 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1. The better films will stand up for a fair amount of time. Trickiest part is getting them installed with no air pockets in the first place.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-02-2013, 08:54 PM   #5
As long as it higher quality and applied carefully without any airgaps, it will hold up fine. I had used some vinyl privacy film on my master bathroom window until we replaced the windows with true privacy glass, and it held up for two years without any problem.
clashley is offline   Reply With Quote
Old 04-03-2013, 12:05 AM   #6
Thanks everyone for your input.
Will Thinset stick to Vinyl Window? HandyFrank Tiling, ceramics, marble 2 11-29-2011 01:12 AM
How can I vent a bathroom exhaust fan out of the window without it looking hideous? mizrachi HVAC 11 12-01-2010 09:14 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
Shrink Film Window Insulation miserlou General DIY Discussions 10 11-24-2008 07:19 AM
Code requirement to replace bathroom window. Rem8 Building & Construction 5 06-16-2008 03:57 PM
