Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 12-13-2011, 03:51 PM   #1
Where can I buy this door threshold?
I need to replace what is pictured with a higher piece that is identical so that it will meet flush with the 1/2" rrubber sweep on the bottom of the door. I am trying to fill about a 1/2 inch gap. Another door has this same piece, but it is already a 1/2 inch higher, so i'm thinking this type of threshold exists somewhere, I just didn't see it at Home Depot or Lowes.
Thanks for any help.
noone is offline   Reply With Quote
Old 12-13-2011, 04:11 PM   #2
Exterior Construction
Windows on Wash's Avatar
They sell thresholds at Lowes.
It does not appear to be adjustable.
Old 12-13-2011, 04:12 PM   #3
I did not see anything at Lowes.com that looked like it would replace this piece, the one between the arrows. Do you have a link?
Old 12-13-2011, 06:35 PM   #4
Disabled wood vet
titanoman's Avatar
That's integral with the jamb. I don't think you will find it sold separately.
titanoman is offline   Reply With Quote
Old 12-13-2011, 07:52 PM   #5
Residential Designer
AndyGump's Avatar
Send a message via Skype™ to AndyGump
Hey, this is a DIY site...make one.
Andy.
AndyGump is online now   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Windows on Wash (12-14-2011)
Old 12-13-2011, 07:56 PM   #6
I'm just going to buy a 3/4" door sweep, like the one I replaced. Problem solved.
Old 12-13-2011, 08:00 PM   #7
Super Moderator
Those are available at Ace hardware and the Depot---common as can be---it's a flat rubber strip with a barbed strip in each side--Try the Ace --bring that picture with--
Old 12-13-2011, 08:01 PM   #8
Is this for a metal or wood door?
If it's a wooden door read below, if it's metal then just buy a new seal.
That type threshold is a piece of junk anyway. What your missing in the rubber seal that fits into the slots, it's sold in any harware, Lowes and Home Depot. But the reason they always fail is the rubber gets steped on as you walk into the door. I'd remove it and replace it with one that's adjustable. Lowe and HD both sell them and add a new sweep that gets installed under the door itself.
Old 01-09-2012, 08:23 PM   #9
It's a metal door.
This is what I originally installed that is a 1/2 inch deep door sweep. As you can see, it needs about another quarter of an inch on the right hand side as the current threshold slopes. I don't think this door threshold ever had a rubber insert in it. I can't see how one could be fitted to this threshold. See first picture again.
I'd really rather not have to replace the entire door threshold, i'd rather just replace with a larger sweep, but neither Lowes nor Home Depot sell a 3/4 inch deep sweep.
Any ideas on where I can get one?
Where can I buy this door threshold?-photo-1.jpg   Where can I buy this door threshold?-photo-2.jpg
