When Is It Time To Replace Windows? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-10-2014, 07:57 PM   #1
When is it time to replace windows?
Our home as built in '97. We're the second owners. Overall our windows are fine. They work well. A few of them have issues closing at times, but nothing major. When is time to replace windows overall? These are going on 18 years.
dinosaur1 is offline   Reply With Quote
Old 06-11-2014, 03:47 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,268
What type of issues as far as it pertains to closing?
Somethings are serviceable, some are not. Really depends on what the issue is.
There is a tipping point where it becomes cost prohibitive to fix them.
Old 06-11-2014, 04:01 PM   #3
Originally Posted by Windows on Wash
What type of issues as far as it pertains to closing? Somethings are serviceable, some are not. Really depends on what the issue is. There is a tipping point where it becomes cost prohibitive to fix them.
Sometimes when you open the window and then when you close it down and latch it shut....there is a little gap on the window still, meaning a draft are coming through unless you close it really really tight and slam it shut.
Old 06-11-2014, 04:46 PM   #4
Rewards Points: 14,014
Wooden windows?
If so some of the common causes can be there's no primer and paint on the out side edges of the sashes so there expanding from moisture.
Someone painted the tracks where the windows ride up and down, there not suppose to be painted.
Built up paint on the back side of the window stool causing it to bind.
Old 06-11-2014, 04:47 PM   #5
Originally Posted by joecaption
Wooden windows? If so some of the common causes can be there's no primer and paint on the out side edges of the sashes so there expanding from moisture. Someone painted the tracks where the windows ride up and down, there not suppose to be painted. Built up paint on the back side of the window stool causing it to bind.
Vinyl
Old 06-11-2014, 04:50 PM   #6
Rewards Points: 582
its time to replace them when you want to...
Old 06-11-2014, 04:53 PM   #7
PoleCat's Avatar
Rewards Points: 1,652
I have some windows that are over 80 years old. I didn't know they had an expire date.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Gymschu (06-12-2014)
Old 06-11-2014, 04:54 PM   #8
Understood. Some people who built their home like my neighbor probably put in cheap windows originally.
Old 06-12-2014, 06:04 PM   #9
Originally Posted by dinosaur1 View Post
Vinyl
There is no real adjustment or fixing them at this point. Probably as much a function of a poor install to be honest here.
+1
Give me some 80 year old, hard, good wood windows, I wouldn't replace them either.
The Following User Says Thank You to Windows on Wash For This Useful Post:
ben's plumbing (06-12-2014)
Old 06-12-2014, 06:19 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
If you live in the north...next winter put a glass of water next to the window....if the water freezes overnight....you need new windows.
Old 06-12-2014, 06:38 PM   #11
kwikfishron's Avatar
Rewards Points: 818
Most of mine still have wavy glass.
kwikfishron is offline   Reply With Quote
Old 06-12-2014, 07:37 PM   #12
You wouldn't believe me if I told you how much that option (if even available) costs these days.
Old 06-12-2014, 08:24 PM   #13
Rewards Points: 236
my old windows had wavy glass. i still have the main picture window that has leaded glass at the top.
Fix'n it is offline   Reply With Quote
Old 06-14-2014, 07:35 AM   #14
Home Performance
HomeSealed's Avatar
Rewards Points: 712
At 18 years I'd say you are around the useful life expectancy of a low end window... That said, when you should replace them depends on how badly they leak and, when budget will allow, and when you simply get fed up with their poor condition and operation. They are not going to rot out, so if they are rarely used and you are not concerned too much about efficiency, they could potentially sit there for another 10+ years.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Windows on Wash (06-14-2014)
Old 06-17-2014, 01:21 PM   #15
Rewards Points: 37
Triple-paned windows are simply the most energy efficient windows out there. Vinyl is the best insulator for your window panes though they doesn't look good. A relatively new option for homeowners buying replacement windows is fiberglass.
garykerr is offline   Reply With Quote
Time has come to replace Goodman Unit...Help me pick a good new unit cyp555 HVAC 7 10-11-2014 11:06 PM
How much time to replace a hotwater heater TAZ427 Plumbing 19 03-01-2010 03:56 PM
replace anderson windows hobbyguy2002 Remodeling 13 12-06-2009 09:34 PM
vinyl windows, replace or not? leetyson General DIY Discussions 4 08-08-2009 08:38 PM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 06:39 PM
