What Window Size Do I Need? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-08-2014, 04:42 PM   #1
Rewards Points: 169
What window size do I need?
This is what I'm working with. The rough stud opening in 26x36. Would a window labeled 24x36 fit in there fine?
RCGA is offline   Reply With Quote
Old 06-08-2014, 05:04 PM   #2
kwikfishron's Avatar
Rewards Points: 176
First off your rough opening would be 36x26.
You always call off the horizontal number first when ordering windows so a 24x36 slider will not work.
For that RO you would want 35 1/2" x 25 1/2" (net frame) window. Although a 24" would fit in the hole you have to take into account how the smaller window will affect the finish/trim (inside and out)
kwikfishron is online now   Reply With Quote
Old 06-08-2014, 05:10 PM   #3
Rewards Points: 169
Thanks. The main reason for wanting a 36x24 is that the size is very common around here and I wouldn't have to order it (savings).
Could I get away with shaving off 1/4" on each side to make it 35.5" wide?
Old 06-08-2014, 05:27 PM   #4
Rewards Points: 176
If you check I'll bet the 36x24 your looking at is actually 1/2" smaller in each direction.
People are under the impression that ordering a window to fit is somehow "custom" and cost more which is not the case most of the time.
The Following User Says Thank You to kwikfishron For This Useful Post:
ben's plumbing (06-08-2014)
Old 06-08-2014, 06:07 PM   #5
Rewards Points: 582
when we order our windows we tell the sales man to hold the numbers...so in other words...if we want 24x 36 hold....we get exactly 24x 36
Window Size applicable for Shutters DukeLewis87 Windows and Doors 2 05-16-2013 06:54 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
