What Window Brands Offer "between The Glass" Blinds? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-14-2011, 05:29 PM   #1
Rewards Points: 156
What window brands offer "between the glass" blinds?
Pella does of course. Eagle by Anderson does.
I like not having the cords hanging and not having to dust them. Are there any others I don't know about?
strategery is offline   Reply With Quote
Old 09-14-2011, 10:01 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
What material are you looking for? In vinyl, I can say for certain that Gorell and Sunrise do among others.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 09-15-2011, 09:43 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,798
Polaris does in vinyl as well.
Need material type before you can narrow the search.
Old 09-16-2011, 07:30 AM   #4
Just a comment on this type of blinds.....they may be easier to maintain, but reduce the efficiency of the window considerably.
Old 09-16-2011, 09:21 AM   #5
Bill is speaking to the fact that internal mini blinds are not available with Soft-coat Low-e or inert gas fill.
Several manufacturers can still meet energy star with internal blinds but they will not be as efficient as their soft coat low-e counterparts.
Old 09-16-2011, 01:12 PM   #6
Rewards Points: 156
The window I got has blinds between the glass and it is low-e argon filled and the u-factor is .26 according to the specs I got. It was a big improvement from my OLD window.
Even still, sometimes the choice has to be made between performance and cosmetics.
Old 09-16-2011, 05:30 PM   #7
Soft coat and hard coat are two different Low-e types.
There are some internal mini blinds that are in sealed units but they are the minority.
Old 09-17-2011, 12:47 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Who does argon fill with internal blinds??? I don't think I've ever seen that. Hard coat low-e, yes... Argon fill, no. Not saying it isn't out there, I've just not seen it.
www.HomeSealed.com
Old 09-17-2011, 01:06 PM   #9
Rewards Points: 156
Pella. I have the spec sheet of my window.
Old 09-17-2011, 05:56 PM   #10
I have heard of some windows with the magnetic tilt mechanism but not the lift and raise.
Old 09-17-2011, 05:57 PM   #11
Which window? The Designer series does not have the blind in the sealed IGU but in the integrated "storm" panel space.
Old 09-17-2011, 11:44 PM   #12
Rewards Points: 156
Mine is the designer series.
The way it was described to me is that it's a triple pane and the blinds are in between one and the argon gas the other.
Old 09-18-2011, 11:59 AM   #13
It is not triple pane as most folks think of it because the 3rd pane is not a sealed IGU.
Old 09-18-2011, 08:27 PM   #14
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Pella Designer does not have argon fill as it does not even have the blinds in a true sealed chamber as Wow described.... On the magnetic operators, I am very familiar with those, however, I have yet to see one that does an argon fill.
www.HomeSealed.com
Old 10-06-2011, 04:07 AM   #15
Rewards Points: 156
Yes it does.
http://www.pella.com/windows/explore...1&PType=window
Not sure if the blinds between the glass are in the sealed IGU though. The salesperson I bought it from says it is, but I haven't verified that.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 08:42 PM
Window treatment options? bokeh Interior Decorating 13 07-04-2011 01:30 PM
Window Blinds? I see there is no listing.. monique6191 Remodeling 5 08-30-2010 01:26 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
