#1 |
What to use to stick magnetic strip to metal shower door?
I bought a liquid nails and tried it, it didn't work because it was WOOD liquid nails (duh). Would regular liquid nails (I think just the multipupose adhesive) do the trick?
I posted a picture of the stupid thing I did with the wood liquid nails on the shower door if you want a good laugh. It comes off easily enough with a screwdriver. I also put this on my front door (the bottom piece of my handle was sliding around) at the advice of a painter. It seems to have done the trick, but some of the good is sticking slightly out of the side. I can't really scrape that off without messing up the door paint, any ideas? Its hard to get at in the 90 degree corner... THANKS ![]() Bozo the clown |
#2 |
Remodeler
clean all that off and use 100% silicone
#3 |
Tileguy
Clean all of that off and use contact adhesive.
Put it on both surfaces wait fifteen minutes and marry them.
#4 |
Double stick tape will work fine. New doors with the flexible vinyl fillers use it. Get the one without the padding(3M). It's just like scotch tape with 2 very sticky sides.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
#5 |
I tried the silicone just now will post results next time I'm there. Thats not a bad idea, that 3m automotive tape would have worked well also if I put those hooks flat and pressed it in.
| Display Modes | |
| Which way should this shower door open? | mynd66 | Building & Construction | 6 | 03-14-2011 02:44 PM |
| Shower door size question | Mr. Michael | Kitchen & Bath Remodeling | 17 | 02-24-2011 09:11 AM |
| Kohler shower door, tolerances, not sure which size to pick | mslide | Kitchen & Bath Remodeling | 2 | 12-05-2009 12:08 AM |
| I'm New & Need Help With Metal Shower Trim | dawn312 | General Discussion | 2 | 06-06-2009 02:43 PM |
| Maxx Shower Walls Install on Metal Studs? | atilla137 | Plumbing | 2 | 11-21-2006 07:17 PM |
