What Should I Do With This Icehouse Door?? - Windows and Doors - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Bud9051
  • 1 Post By ZZZZZ
  • 1 Post By GrayHair
Old 05-17-2017, 12:17 PM   #1
What should I do with this Icehouse door??
Hello all, new member/first post. I saved this Jamison Icehouse door from a trip to the landfill. My original thought was to make a frame and drop it in to make a table top. I don't want to remove any hinges or latches, so a eating table is not practical, but just a general gathering table should work. My wife had other ideas with it. I know I don't want to paint or stain it. It's got a good look to it as is. What all suggestions do you have? I want make it a functional piece of furniture.
What should I do with this Icehouse door??-img_2243_1495041414304.jpg   What should I do with this Icehouse door??-img_2241_1495041434180.jpg   What should I do with this Icehouse door??-img_2238_1495041453481.jpg
BrannonB is offline   Reply With Quote
Old 05-17-2017, 12:38 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,390
Re: What should I do with this Icehouse door??
That's a great find... full of character....
Maybe a back counter to a bar or game room... with the hinges mounted up horizontally on the wall...
Or, depending on the entry walkway to your home... maybe a completely phony door on the walkway... just posted in for decoration
MTN REMODEL LLC is offline   Reply With Quote
Old 05-17-2017, 12:47 PM   #3
ZZZZZ's Avatar
Rewards Points: 2,736
How heavy is it?
Interior sliding "barn doors" are all the rage. This would make a great sliding door if it's not too heavy to put on a track, though I think you'd have to remove the hardware.
The way the hinges stick out the side like that, it might pose a safety hazard if you make any kind of interior table.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is offline   Reply With Quote
Old 05-17-2017, 12:49 PM   #4
Rewards Points: 4,262
As a table it wouldn't be just an issue with the hinges and the handle but all of the trim.
Just a thought, not necessarily a good one, but you could provide a frame to attach the hinges and then cover the entire door with a glass top. That would preserve the door and its looks while providing a nice very large table.
Bud
Bud9051 is offline   Reply With Quote
Old 05-17-2017, 01:32 PM   #5
ZZZZZ's Avatar
Depending on your available wall space and taste in decor, I might just mount the whole thing on the wall as a piece of art deco or art nuveau or art whatever you want to call it.
That, or you'll just have to build your own ice house to put the door in front of.
MTN REMODEL LLC likes this.
Old 05-17-2017, 03:20 PM   #6
GrayHair's Avatar
Rewards Points: 1,002
Some clear Lucite "ice cubes" acting as spacers to support a tempered glass top of suitable thickness? (Particularly if 4 sides of the cubes are wavy to resemble ice.) The corners of the top should be rounded and the edges ground with a slight radius (unless you put the top in a frame). A pair of iceman's tongs (for blocks, not cubes), an ice saw, some ice-picks, etc, scattered on the door should add interest.
EDIT -- The glass top should probably be larger than the door to protect people from the projecting hinges.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Mahogany Door Jamb - What nails and where? Toronto Carpentry 25 07-26-2012 07:08 PM
Exterior Door won't seal Rhomadri Windows and Doors 8 04-28-2012 09:27 AM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 05:45 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 03:01 AM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 08:43 AM
