What Is Proper Amount To Take Off For Retro Fit Windows? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 01-18-2012, 06:04 PM   #1
Question
What is proper amount to take off for retro fit windows?
I am replacing windows at my home. The windows are currently the old double hung single pane wood windows from the 1950's. I want to replace with milgard alumnium windows with low e as a cost saver. There is a slope on the sill.
I have read some sites state take a 1/4" off the narrowest width and height. Others state, 1/4" off the width and 1/2" off the height.
Which is correct?
I appreciate the input.
Regards,
Jim
jimleahman is offline   Reply With Quote
Old 01-18-2012, 06:56 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Take what off of what?
titanoman is offline   Reply With Quote
Old 01-18-2012, 07:03 PM   #3
specifics
Sorry, I wasn't clear.
I meant to take off the original measured rough opening for a new window.
For example, if my window height measures 54" would I order a new window with a height of 53 1/2" or 53 3/4"?
I am not sure if the width and height of the new window should be 1/4" or a 1/2" less than the rough opening measurement?
Thanks.
Old 01-18-2012, 07:29 PM   #4
Disabled wood vet
titanoman's Avatar
A rough opening should be 1/2" bigger both ways.
Find out what the window measures and adjust the opening accordingly.
Make sure it is plumb and square.
Old 01-18-2012, 07:38 PM   #5
Rewards Points: 13,748
Is this new constrution windows or replacement windows?
I'd never order aluminum windows, or even aluminim clad windows.
The cold or heat transfers into the house through the aluminum.
I've seen way to many times there clad windows leak behind the clading and the frames rot out.
I've replaced many an Anderson and Pella window because of this.
A vinyl window will not do that.
Old 01-18-2012, 09:31 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,760
Totally depends on what the installation methodology is.
If the opening is relatively square and it is a pocket install, we usually do a 1/4" cut back.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Tom Struble (01-20-2012)
Old 01-19-2012, 06:19 AM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+2... It depends on the home. If the openings are very square, 1/4" is ideal. Most are not around here, so my default is 3/8 off the width, and 1/2 off the height. Typically that allows plenty of room to get the window square, add foam, and still get coverage from all of the interior stops ( without using a head expander or anything).
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Old 01-20-2012, 12:33 PM   #8
Thanks everyone. I took a 1/4" off the width and the height for the new replacement window per the suggestions. My windows measured out almost all square with the exception of an 1/8" off on only a couple windows.
Since I already have one newer aluminum window, I decided to replace the one adjacent to it with the same aluminum window and the rest with vinyl.
Old 01-20-2012, 12:54 PM   #9
Rewards Points: 133
Both lowes and Home Depot offer free In-Home Window Installation Consultation. I believe both will measure all your windows for you, and spec out the windows and give you a quote. You might have to listen to a sales pitch, but you are not obligated to buy, and you'll have all the proper measurements you need to order your windows should you want to do them yourself.
jimmyfloyd is offline   Reply With Quote
Old 01-20-2012, 05:22 PM   #10
Rewards Points: 774
In the end it won't make that much difference. Do you know the rough opening measurements? If you do, just give whoever you're ordering from the measurements of the rough opening and their system will do that for you. Same if you give them the actual window measurements. I don;t think I have ever had to subtract anything.
cibula11 is offline   Reply With Quote
Old 01-20-2012, 05:29 PM   #11
Home Performance
HomeSealed's Avatar
Rewards Points: 712
As much as I dislike the "installed services" of those two companies, that suggestion is poor form. It may be a "free" estimate, but it still costs money to send someone to your home. What you have suggested would be no different then if you walked into HD and walked out without paying your merchandise. It is stealing. Secondly, I'm not sure how they work, but many companies only get general measurements on the initial appt, and then send someone more qualified back to get the exact measurements.
www.HomeSealed.com
kwikfishron (01-20-2012)
Old 01-20-2012, 07:13 PM   #12
as far a home depot
as far as home depot, the sales guy said they wouldn't give out the measurements. i asked already. makes sense they would not for a free quote.
Comparing Replacement Windows Amycat Windows and Doors 72 05-31-2014 08:56 AM
New windows and doors for remodeling Andee77 Building & Construction 2 10-10-2011 02:27 PM
Measuring for retrofit windows mday83 Windows and Doors 5 08-14-2011 07:49 PM
Dual Pane Windows No Low E Glass and No Argon Gas Filling AZSun Windows and Doors 4 08-12-2011 09:10 PM
New replacement windows got wet - Problem? scnd1016 Windows and Doors 1 07-10-2011 06:47 AM
