What Is The Door Surround Made Of? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-05-2012, 09:47 PM   #1
What is the door surround made of?
Before I start in on a few summer door projects (replacing jamb rot and installing a storm door). I need to know what the surround is made of.
Any ideas? It kinda looks like stucco to me, but I am not sure.
JMedwick is offline   Reply With Quote
Old 07-05-2012, 09:54 PM   #2
Rewards Points: 13,712
Looks like James Hardee trim. It's a royal pain to deal with.
Instead of a storm door concider just buying a better door.
Looks like just a cheap metal door.
A fiberglass door with adjustable sill, flat vinyl jambs and will seal better, never rot or need paint.
The adjustable sill will make up for any out of level area under the door.
Old 07-05-2012, 09:54 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
stucco covered foam,probably not a diy type of thing imo
Tom Struble is offline   Reply With Quote
Old 07-05-2012, 10:01 PM   #4
Haverhill Trade 1965
I'm with Joe & Tom. If it isn't those, it is something similar. Tap on it. if it sounds like a crack then it is probably cement fiber. If it sounds like a softer thump it is probably a foam base.
Duckweather is offline   Reply With Quote
Old 07-05-2012, 10:26 PM   #5
Thanks for the comments. Knocking on the stuff gives me a hard but not hollow sound. Seems like a foam base absorbing the sound.
I was looking to instal the storm door as a compromise to allow light and spring/fall breezes with the added security of full door behind it. If it is foam in the center, I really don't have anything in which to anchor the door. Any thoughts on how I could install such a door (other than taking out the stucco and redoing the whole door frame)?
Milwaukee tool made in China KUIPORNG Tools 63 08-31-2011 01:10 PM
Made in USA nail gun? sray100 General DIY Discussions 3 12-17-2010 06:49 AM
Any guidelines as far as how big, how many, or where the holes can be made in wall ? chrishallowell Building & Construction 3 09-03-2010 09:01 AM
So WHY is this car not made NOW ?? 100 mpg, 135mph Scuba_Dave Off Topic 6 04-27-2010 03:16 PM
Made in USA ??????? Giles General DIY Discussions 12 04-17-2010 01:21 PM
