Weatherstripping On Inside Of Window Warping? Help! - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-17-2013, 07:59 PM   #1
weatherstripping on inside of window warping? help!
Hi everyone,
I have a bunch of windows that appear to have weatherstripping on the inside of the window? and its warping and hanging down. Does anyone know of a way that I can get at these? Thanks for any help!
Adam
weatherstripping on inside of window warping? help!-photo-1-.jpg   weatherstripping on inside of window warping? help!-photo-2-.jpg
MacrosTheBlack is offline   Reply With Quote
Old 10-17-2013, 09:57 PM   #2
Rewards Points: 13,732
And then what? Those windows are ether defective or somehow they got super heated to have that to have happened.
Do you have one of those plastic domes over that window well?
Old 10-17-2013, 10:04 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,676
Defective.
Seal failures are common with builders grade or cheaper replacements.
You cannot get to those and they will require glass or sash replacement.
Are you the original purchaser of the windows? Can you locate the manufacturers information?
Old 10-17-2013, 10:10 PM   #4
These windows are all on our 1st floor. It's happened to windows on the front, back, and side. The window on the side doesn't get much sunlight. The front and back gets direct sun. We live in Illinois.
Old 10-17-2013, 10:17 PM   #5
Originally Posted by Windows on Wash View Post
Defective.
That's what I was afraid of. The house is about 14 years old. We're the 3rd owners I believe. I assume these are builders grade. Other houses in the neighborhood have them as well. Seems like I'll have to get them replaced. Thanks for your help!
Old 10-18-2013, 02:12 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1, no fixing that. You could replace the glass only, but for 14 yr old builder grade windows I would not spend a penny on them. Best to replace.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following 3 Users Say Thank You to HomeSealed For This Useful Post:
gregzoll (10-18-2013), joecaption (10-18-2013), Windows on Wash (10-18-2013)
Old 10-18-2013, 04:51 PM   #7
Time for new windows like HomeSealed said.
Sorry.
Where in IL are you located? Chicagoland area has some great window options.
Old 10-18-2013, 06:14 PM   #8
Sorry.
Oswego. Southwestern suburbs of Chicago.
I was hoping for a cheaper fix, but alas, new windows it is.
Old 10-19-2013, 10:12 AM   #9
HomeSealed isn't too far from you at that point but you are correct.
You are going to need new windows.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
Can I replace a window from the inside? Ultrarunner2017 Carpentry 14 04-28-2009 03:08 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Grill slipping inside window CharlieCoe General DIY Discussions 1 12-20-2008 09:22 PM
