#1 |
Weatherstripping entry door to garage
I have a Solid wood plan entry door that leads to my garage. The door seems to have no threshold and there is no "kerf" cut in the jamb for weatherstripping. I noticed I could see light on the bottom side so I removed and replaced with the adhesive "Frost King" stuff. The door became difficult to close and I noticed on the bottom "non-hinge" side I could see light. I replaced it will the non-silicone type and it worked better but I could still see a crack of light on the non-hinge side. Upon closer examination I see the door doesn’t close even. I guess from regular use. What type of weatherstripping is best to use. I see they sell the Screw in type of weather stripping. I also notice when I place the weatherstripping on the top side it tends to lump up on the hinge side. Also the door had a rubber screw in type of sweep. I noticed the sweep makes it difficult to close the door. Should I use the sweep that attaches to the door bottom??? Someone nailed a gold transition strip to the bottom of the door “threshold”.
#2 |
Disabled wood vet
Foam weather stripping has enough give to absorb bad irregular seals without making the door hard to close. It doesn't last forever, but it's cheap enough. And a broom sweep screwed to the face of the door has an adjustment at every screw (5 or 6) to seal irregular gaps under the door. Is it an exterior door? I wonder why no threshold. That's usually part of the jamb.
#3 | |
Weatherstripping entry door to garageQuote:
| Display Modes | |
| Expanding Garage INTO house (goodbye Den) | texaopian | Building & Construction | 16 | 11-07-2011 11:32 PM |
| Garage Insulation | yamster | Insulation | 0 | 07-01-2011 02:30 PM |
| Do I have a Fire Rating Issues with Attached Garage | Perry401 | Building & Construction | 4 | 04-26-2011 12:58 AM |
| Problem with garage door side entry | thundercloud | Carpentry | 6 | 06-09-2009 07:27 AM |
