Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-14-2012, 10:18 AM   #1
Water Seeping in Between
looking at the windows in my house, none of them have a glass barrier right next to the insect screen, so water can seep in between the screen and the main glass, into what i'm assuming is the wall. is this how these windows are designed?
Uploaded with ImageShack.us
Scully is offline   Reply With Quote
Old 10-14-2012, 11:01 AM   #2
Go outside and look at the bottom of the window frame. See any drain holes with little flapper type covers on them?
Better yet close and lock the window and mist some water on the glass.
It should rin down and drain out under the bottom of the screen, any extra drains out the built in drains.
Old 10-14-2012, 11:55 AM   #3
most of my windows (installed in 1999) have these vents on the outside and inside.
I have one newer window with these vents:
Old 10-14-2012, 11:58 AM   #4
That's where the water run back out.
Need to make sure those sills stay cleaned off to gett the drains from plugging up.
One reason I like 1/2 screens better then full screens. With 1/2 screens I can remove them easly and just hose the window down from out side.
Old 10-14-2012, 12:09 PM   #5
so these window sills that i have, are completely encapsulated and not exposed to the interior of my walls (plaster)?
what do you mean by 1/2 screens and full? is that what i have, 1/2?
Old 10-14-2012, 12:18 PM   #6
There suppost to have welded seam so the frame become like one piece.
If your screen takes up the whole window frame it's a full screen.
Old 10-14-2012, 12:28 PM   #7
how can i tell if the frame is welded like one piece and not exposed to the interior of the walls? i'm just concerned about water getting into the walls.
also, how do i clean the grooves in the sills? circled in red.
Old 10-14-2012, 12:41 PM   #8
There is no great way to clean them out. That vinyl piece on the sides can be slid up for more room and use a crevis tool on a shop vac, use a pipe cleaner in the other hole.
Have you seen any water getting in on the inside? If not just clean it the best you can and not worry about it.
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
