Water Leaking Into Basment Through Window. Please Help - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-18-2013, 12:58 AM   #1
Rewards Points: 12
Water leaking into basment through window. please help
We are getting lots of rain currently and i have lots of water coming in from around the bottom trim/frame of my basement window. It is a small window near the top of the wall (typical basement window). There is a deck over the window so there is no access to the well from above. It is in the utility (unfinished) side of the basement and the water is already migrating into the carpeted area.
My question is, how do I go about fixing this problem? Can I simply caulk it once the rain stops and it dries up, or is there an underlying problem thats the issue that caulking simply won't fix?
Luelf21 is offline   Reply With Quote
Old 04-18-2013, 06:30 AM   #2
Rewards Points: 13,256
Problum needs to be addressed outside not inside.
May have to just remove some deck boards to get to it.
Old 04-18-2013, 07:17 AM   #3
Rewards Points: 12
Could you please specify what exactly needs addressed outside please? What kinds of things should I be looking for. One thing I do know is that the window well is not flooding...
Old 04-18-2013, 07:40 AM   #4
Without at least a picture of the outside it's hard to say how to fix it.
Rotten wood, needs to be caulked, drain holes caulked over, sill below grade ECT.
Old 04-18-2013, 07:48 AM   #5
Rewards Points: 2,516
Is the land graded toward the house in that area? Is there a downspout close by?
hammerlane is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 05:10 PM
Water filling up window well pb2 Building & Construction 17 08-20-2012 05:08 PM
Leaking Pipe above hot water heater with pics notarock Plumbing 9 07-30-2011 09:29 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
