Water Around Window - Windows and Doors - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-27-2013, 12:46 AM   #16
Rewards Points: 12,802
That's the way I would have done it.
Once the windows are on site you make a cut down the middle starting and finishing about 12" from the opening.
Then a diagonal cut in each corner toward the middle.
The sides and bottom get folded into the opening stapled and trimmed off.
The top gets cut straight across the opening and two small cuts are made vertical to form a flap.
The flap is to be used to cover the top of the nailing fin.
You apply caulking to the back sides of the nailing fin before installing the window.
Old 12-27-2013, 12:36 PM   #17
Registered User
Rewards Points: 4,894
Yes, the tape on the bottom shows they didn't know proper install, I was not inferring it leaked there...
" From my understanding the overall issue is it being too tight, with no room for expansion or contraction, in conjunction with the way its fastened."---------- I don't see any evidence of it being tightly nailed from here.... the angled fastener head is wrong though- it has to move in the slot allotted.
Maybe they just cut the HW flush with the rough opening... the HW keeps the liquid water from the sheathing (imperative) while allowing water vapor to pass through. It should have a continuous bead (except at bottom sill) of caulking/sealant between window/HW/sheathing, on pages 32-35;http://www.google.com/url?sa=t&rct=j...58187178,d.cGU
OR per your HW instructions.
Gary
Installing an electric water heater in series with boiler paul01420 Plumbing 10 04-20-2013 09:48 PM
Water filling up window well pb2 Building & Construction 17 08-20-2012 05:08 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
