Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 02-19-2013, 09:51 PM   #1
valcarmo72's Avatar
Warped Solid Mahogany Exterior door..
I have a Masonite Brand Mahogany door with big oval glass in the middle. The top right corner is slighlty warped. I have full sun hitting the door from noon on. In the summer the door is straight. But in the winter it warps the top right corner allowing a draft. Does anyone think a storm door to seal off the draft will help with the warping issue also?....here's a pic of the door. I think the previous owner got it from Homedepot..Thx in advance for the help..
valcarmo72 is offline   Reply With Quote
Old 02-19-2013, 09:59 PM   #2
Beware Masonite doors
i would want a good storm door, if for nothing else, added security.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 02-19-2013, 10:14 PM   #3
valcarmo72's Avatar
Hey listen I figured that being as it came from Home Cheapo..but what can I do now. Im not one to bandaid stuff but can't afford a new door. I'm actually thinking if buying nice solid door and moving the glass into the new door. Door looks awesome. Just refinished it but in the winter I get that warp in the corner. Previous paint flakes right off. I stained it..3 coat of exterior poly after. Sucks the door is warped. U can't correct that..right?...once its warped its done..no?
Old 02-19-2013, 10:56 PM   #4
well, anything can be fixed. what it comes down to is = is it worth it ?
you said top right corner. is that the hinge side or knob side ? perhaps you could shave 1/8th" off the top and side. then screw 1/8th" pieces of steel in place.
Old 02-19-2013, 11:01 PM   #5
or, as you said. a storm door could keep the main door just warm enough to not warp.
do you "have" to use this door every day ? if you can leave the door unused for a few days = put a piece of wood, insulation board, or something, on the outside to seal it off. if the door unwarps, then you have your answer.
The Following User Says Thank You to Fix'n it For This Useful Post:
valcarmo72 (02-20-2013)
Old 02-19-2013, 11:07 PM   #6
valcarmo72's Avatar
Knob side..top of the door...good advice. I know for a fact that the sucker goes back to being straight after the weather is warmer. Has happened for three years. You know that not a bad idea. Maybe ill router out the half way down the door and put a piece of steel in it to keep it from warping. Sounds like a plan. When the weather allows it to snap back into place I'll try it. Let u know what happens. Might take a year though to get back to u on that one. LOL...but I will...Thx man..
Old 02-19-2013, 11:16 PM   #7
i would put the steel the full length.
good luck. and keep us posted, even after a year.
Old 02-20-2013, 09:20 AM   #8
Dark colored door, direct sun, Hmm.
Any door company I've every delt with has warnings about using to dark a color when it's in the dirct sun.
Adding a storm door will just turn that door opening into a solor panel and add to your problums.
I've seen two of that same door both brand new, both did the same thing.
The factory sent someone to replace both doors at no charge.
It took a while because they sent a rep. that was 1-1/2 hour away to first look at the door.
Old 02-20-2013, 09:33 AM   #9
valcarmo72's Avatar
I didn't buy the door. Thats my biggest issue. I wish I had a reciept. There is a manufactured date on it though. I would have never did that..I knew about the dark door and sun theory...I'm standing 15 feet away from it right now and the draft is hitting my feet....LOL. gonna try to change the seals for now.
Don't know?...ask someone...
Acrylic Solid Stain vs Oil Semi Trans or Semi solid torxx Painting 19 10-03-2012 09:37 AM
New construction - warped wood NewOwner32 Roofing 17 09-11-2012 06:42 PM
Just bought house with peeling solid stain, best way to fix? mitch12533 Painting 0 06-30-2012 12:25 PM
Solid Staining Mahogany Door Earnie Painting 1 05-24-2012 03:46 PM
Solid Surface vs Granite and Quartz jbeall General Discussion 26 03-15-2011 04:49 PM
