Viwinco OceanView Impact Window Opinions Needed - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 09:38 AM   #1
Viwinco OceanView Impact window opinions needed
I have had continuing leaks around my (3) 4x5' picture windows for the past few years. I have finally decided to take all the siding off that outside wall and replace the windows and the siding. The contractor recommended Viwinco windows (I have Anderson there now) because they have an impact resistant window available and I live in a high wind area.
I have a few questions about these windows. One person on this forum said they've been using them for 20 years and are happy with them. I want to know if the laminate they put on the glass that makes it impact resistant diminishes the optical clarity and does it ever yellow, bubble or fail in any way?
Thank you!
h82diet is offline   Reply With Quote
Old 11-12-2011, 05:40 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,092
Laminated glass does not yellow, bubble or delaminate.
Depending on where you are located, it may be entirely unnecessary and a bit expensive.
Old 11-12-2011, 09:22 PM   #3
We live on the top of a small mountain and when the wind blows we can see the INSIDE pane of glass on these three window bow. When the winds are predicted to go over 75mph, I drag out these plywood inserts for the windows and screw them in place and I'm sick of doing this. I'm also worried about someone losing their balance (as my elderly mom once did) and falling into one of these windows which start 12 inches off the floor. I thought Anderson windows were good quality when I was building the house so I used them. The inside trim is wood (vs. the vinyl of the windows I'm considering) but the fact that the glass is so thin and the windows leak has left me disappointed.
Old 11-13-2011, 08:11 AM   #4
I have used Viwinco products for 20+ years, and find them to be a reliable company. I have also used Andersen for a LONG time, excellent products. You can't compare the two, different products. If you have Andersen windows, I would replace with Andersen. As for the glass, they have to meet certain ratings to be qualified for that purpose, usually ASTM or similar. If it is rated for impact, it meets those requirements.
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 09:01 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
Window jamb helpless handyman Carpentry 11 08-03-2006 12:45 PM
